PS3 40gb laser
  • sienoki
    sienoki
    • Jan 2012
    • 314
    PS3 40gb laser
    Hi people..just got a ps3 model cechg03 one with 2 usb ports at front from a friend for fixing his pc..the ps3 is fine apart from not reading any type of discs..no spinning disc icon no nothing..so the laser is dead or just needs cleaning..im awaiting on sum isopropanol from ebay..my question is whats the best place in uk to get a replacement lens..the unit has never been opened before aswell..thx
    Re: PS3 40gb laser
    Got a blu-ray drive from a PS3 80GB if you're interested...
    • sienoki
      sienoki
      • Jan 2012
      • 314
      Re: PS3 40gb laser
      You cant just replace the full drive can you?..does it involve firmware or sumat..never done owt like that before..
      I believe mine is a single laser either kem/kes-400aaa as it takes the disc straight in..so can your drive tom be put into mine with just replacing the boards..thx
      • selldoor
        Slow Learner
        • Dec 2010
        • 7870
        Re: PS3 40gb laser
        I have always been lead to believe that the drive board and the mainboard have to be matched and should not be split. No doubt there will be a way of reprograming both so there is recognition but the way to go seems to be keep the board off the matched drive and replace the laser mechanism
        • sienoki
          sienoki
          • Jan 2012
          • 314
          Re: PS3 40gb laser
          Thought as much..probably get 1 from http://www.ebay.co.uk/itm/NEW-Sony-P...c9952c9b..then sell it on closer to xmas..thx
          • sienoki
            sienoki
            • Jan 2012
            • 314
            Re: PS3 40gb laser
            Bought another same model no hdd or caddy & cracked lid for 20quid..abit of swapping over & alls good..need 2 sell em now..thx
            • Junior††
              PS5 Disc Not Supported/ Disc Not Recognized Board Num: EDM-020
              by Junior††
              Good Afternoon fellas,
              Issue:
              Disc is showing as not supported when a disc is put in.
              Here's what I've done, you can skip this if you just wanna know the question:
              - replaced with a disc drive from a donor ps5 (honestly questionable if this is known to work)
              - reflowed the disc drive connector
              -reflowed the chip in question (shown on image)
              - I will say this console was very dusty so it's conceivable that it got so hot that it made the chip joints cold and potentially other things on the board
              Question:
              I...
              02-19-2025, 12:48 PM
            • dkneyle
              Onkyo DX-V500 Laser Disc Player - weird SMPS fault
              by dkneyle
              This relic from a technology path that came to a dead end (but still has historical interest) was brought in with a dead SMPS, which is based around a MK1210 device. I got it going after a battle. It seems to have a strange design - if it's not getting feedback that the secondary is OK it cause the big FET to go into full conduction and overloads resulting in a blown fuse at best or something worse! I'm using a Dim Bulb Tester (70W/230V) which thankfully has saved the day a number of times whilst repairing.
              Now, it loads a CD OK. The motor voltage output (which is built onto the SMPS...
              02-01-2022, 02:08 AM
            • Dannyx
              Hilti PD30 Laser Range meter Error 276
              by Dannyx
              Good day folks.....wow, seems like forever since I posted anything here Still alive and well, thank you I guess you could say I've become more independent and able to work stuff out on my own. This one though goes way over my head and I doubt is fixable, but maybe some bright spark out there has an equally bright idea.
              So: my Hilti PD30 laser meter quit on me just the other day. It was working fine, I set it down for a while and when I tried using it again it gave me an E276 and wouldn't do anything else. I tried taking out the batteries, all that standard stuff but nothing...
              07-30-2023, 05:05 AM
            • ahmedtou
              HOW CAN I UPDATE HL-DT-ST BD-RE GGW-H20N XA02
              by ahmedtou
              help me please
              I have an HL-DT-ST BD-RE GGW-H20N with ROM version: XA02.
              When I tried to burn a 25GB Blu-ray disc using ImgBurn, I got an error.
              I will share all the details with you, including the disc information.
              Code:
              HL-DT-ST BD-RE  GGW-H20N XA02 (ATA)
              Current Profile: BD-R
              Disc Information:
              Status: Empty
              State of Last Session: Empty
              Erasable: No
              Free Sectors: 12,219,392
              Free Space: 25,025,314,816 bytes
              Free Time: 2715:27:17 (MM:SS:FF)
              Next
              08-27-2025, 08:49 AM
            • dansity
              Power DeWalt 12V laser measure from power supply
              by dansity
              i got a Dewalt laser measure which uses the 12V batteries to operate. The laser measure is faulty and I want to attempt a repair, never fixed such thing before. You might see a different topic if I fail with the repair
              However I do not have dewalt batteries nor want to buy one for 140EUR as the laser tool might have some chance that it is very hard to repair or unrepairable.
              I want to power it from my PSU.
              The tool has 3 input pins, on the battery it is marked with B-, B+ and ID/TH.
              i want to know what is the third pin exactly and what do I need...
              10-29-2023, 03:04 AM
