Xbox 360 No Power
  • xboxhaxorz
    • Jan 2011
    • 196
    Xbox 360 No Power
    I have a 360 that doesnt turn on with power it gives instant RROD. I have looked at a few guides about mosfets but they seem to be different in the steps.
    For example this guide says i need to touch the neg to the drain pin and the pos to the gate.
    http://forums.xbox-experts.com/viewtopic.php?f=8&t=538
    Then this guide says to touch the neg to the source and the pos to the gate then drain.
    http://in.answers.yahoo.com/question...6230136AA6Blij
    This guide says the same thing as the instruction from yahoo
    http://www.4qdtec.com/mostest.html
    So far i have removed the coils so that i can test the mosfets without removing them from the board
    http://forums.xbox-experts.com/viewtopic.php?f=8&t=3698
    I now have the problem of figuring out which mosfets are bad, since the instructions are confusing
  • bsweasel
    • Jun 2010
    • 82
    Re: Xbox 360 No Power
    The first link you posted seems pretty self explanatory and sounds right to me. I'm not an expert at this stuff. But if you read up on mosfets, that post makes perfect sense to me and seems like a logical way to test if it the fet is working.
    • digge
      • Apr 2006
      • 296
      RROD is a very general error, typically means hardware fault. Can be anything from reballing/reflowing the cpu/gpu to bad power or bad caps.
      Just curious why you think its a power problem, what lead you to that conclusion?
      I have a broken one with same problem that i still havn't gotten around to look at
      • xboxhaxorz
        • Jan 2011
        • 196
        Well it depends on the error code for this console its 0001 and it turns off right away. Other error codes such as 0102 indicate the need for reflow/ reball, its all in the codes.
        • Toasty
          • Jul 2007
          • 4171
          Check the power supply itself.
          veritas odium parit
          • digge
            • Apr 2006
            • 296
            Ahh, so you had the error code at hand, not just the rrod. Like toasty said I've heard of bad caps and similar in the psu so that might be worth checking out before digging to deep inside the box, or if you have a friend with a working xbox borrow their powerbrick and try it first before proceeding to save some troubleshooting time.
            • Toasty
              • Jul 2007
              • 4171
              *BUMP*
              veritas odium parit
              • TMTGTR
                An Xbox One PSU Odyssey
                by TMTGTR
                Firstly I am not a tech. You guys may see mistakes or oversights in my methods so don't be bashful and feel free to post corrections/opinions.
                =>Background:
                I bought my son a used Xbox One original model: A12-220N1A Rev: 02 with original PSU & 2 controllers 7 years ago. I “modded” the unit placing a 4.5” 12V exhaust fan with a 9v wall wart adapter on top of the vent/fan of the unit. And plugged the Xbox PSU into a Tripplite LTR-600 voltage regulator. Also connected to the Tripplite are a 275w computer tower, an Xbox 360 PSU and a Westinghouse 52” LED TV. ...
                06-17-2022, 05:40 PM
              • CZFan
                XBox One PSU Mosfets
                by CZFan
                Hi All,
                My original PSU for XBox popped a little while ago, openened it up, fuse gone, mosfets shorted, etc. I ordered a cheap one (Not Microsoft Original). This one also popped the weekend, opened up, and needed a couple of Caps to be replaced, as the saying goes, "it is always a cap..."
                When I opened the replacement I bought, it has about 25% of the number of componenets compared to the Microsoft original, which is expected I suppose for the 1/4er of the price, but the bloddy thing does not even have a fuse in!!!
                Unfortunately wife has cleaned...
                01-18-2024, 07:10 AM
                HP EliteDesk 800 G3 + ProDisplay P240va + Seagate Game Drive for Xbox 2TB Green EliteDesk 800 i5-7500 Specification for Upgrade or Repair
                This specification for the HP EliteDesk 800 G3 + ProDisplay P240va + Seagate Game Drive for Xbox 2TB Green can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the EliteDesk 800 G3 + ProDisplay P240va + Seagate Game Drive for Xbox 2TB Green boardview and EliteDesk 800 G3 + ProDisplay P240va + Seagate Game Drive for Xbox 2TB Green schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively...
                09-12-2024, 02:00 PM
              • Stevedb
                Boardview xbox 360 , xbox fat , xbox one x and xbox one s
                by Stevedb
                Hi all
                I will share the boardviews i found internet from the xbox 360 , xbox fat and xbox one x and xbox one s
                Pasw netcomchetumal.
                Enjoy it.
                Greetings Steve
                From Belgium...
                04-04-2023, 12:42 AM
              • BlackScreen_22
                Harman Kardon sub TS11 (ds15 amplifer) blows fuse and mosfets
                by BlackScreen_22
                Hi, I'll start by saying that I'm not an expert and I've reached a point where I don't know what to try/do anymore...
                Starting from the beginning: I opened this subwoofer for the first time with a very strong smell of burnt electrical components, I realize that on the amplifier board there is a hole between V+ OUT and GND about the size of a finger, the damaged components were the shorted mosfets, two damaged zener diodes and two capacitors. I bought everything, I fixed the hole by cutting the pcb and putting a piece of a perforated board.
                I had no problems connecting mosfets and capacitors,...
                08-27-2024, 12:46 PM
