PS5 cut off or freeze on main menu
  • JonnyS
    • Apr 2016
    • 9
    • Poland
    hi
    i have a problem with PS5
    that cut off or freeze on main menu
    i try to rebuild database - not helps
    reinstall software and factory reset - not helps not helps
    can somebody have idea what i can do more ?
    i will be very thankfully.
    kind regards
  • LaPCon_IT
    • Sep 2022
    • 82
    • Malta
    Re: PS5 cut off or freeze on main menu
    How long does it take from powering PS5 on, to the moment it freezes? Try couple of times and check if that time is constant or not.
    • stormanimal83
      • May 2014
      • 74
      i think you got problems with ram... or the connection from apu to ram...
      please visit the youtube channel of Phil TheCoder... he tried several times to repair a console liuke that. he is also the person that made possible to change a disc drive edition with broken disk drive to digital edition to make the console work again....
        • 31296
        or watch him live most nights
        https://www.twitch.tv/thecod3r2015
        • JonnyS
          • Apr 2016
          • 9
          • Poland
          hi
          thanks for a quick answer.
          Time to freeze is not constant but freezing is everytime when i try to run a any game.
          stormanimal83 :i subscribing a the cod3r YT channel but i cant find any similar case
            • 31296
            if you catch his twitch stream you can ask him.
            • stormanimal83
              • May 2014
              • 74
              did u try to insert an additional ssd and run games from there? possible internal ssd fault? from my experiences you could use a cheap crucial p3 plus. i bought one for my pc and wanted to know if the ps5 is recognising it cause it is a bit to slow but still an pciexpress 4 device.... and yes it is... not the fastest ssd u can use but the cheapest possible... my console accepted it. my console has a samsung 980 pro heatsink 1tb normally... i was curious and changed them before i built up the pc...
              Last edited by stormanimal83; 08-01-2023, 09:34 AM. Reason: added pic, corrected typing
                LCD LED TV Service Menu Codes
                TCL LED TV Service Menu Code
                LG LED TV Service Menu Code
                10-31-2024, 03:58 AM
              • ygorsan
                by ygorsan
                🧩 Problem Summary:
                • I
                07-28-2025, 08:34 AM
              • cheeky2
                by cheeky2
                05-25-2024, 03:27 AM
              • Asraf Atb
                Help Needed: Samsung UE55MU8000 Dead - Possible Main Board Issue
                by Asraf Atb
                Im looking for some advice regarding my Samsung UE55MU8000 TV with main board model BN94-11606C. The TV suddenly stopped turning on and now shows no signs of life at all not even the standby light at the bottom.
                Initially, I suspected an issue with the PSU, so I took it to a repair center. They tested it and confirmed that the PSU works perfectly, even on other TVs. Based on that, I started investigating the main board.
                I disconnected the main board from the PSU, and the backlight turned on, which seems to confirm the main board is the issue....
                01-27-2025, 05:02 PM
              • Genghis_Khan
                ThinkPad T470p – CMOS Checksum Error Persists After Main Battery Removal (even with new CMOS)
                by Genghis_Khan
                I’m currently troubleshooting an issue on my Lenovo ThinkPad T470p (Type 20J6) and would really appreciate any insights or solutions.
                Issue summary:
                Whenever I remove the main laptop battery and AC adaptor, then place them back, the system gives a “CMOS checksum error” at next boot, and the BIOS clock resets to its default time/date.
                However, the RTC works fine as long as the main battery remains attached — even if the laptop is unplugged for hours. Same as I remove the battery while the AC is attached, RTC remains. Obviously,...
                11-11-2025, 11:51 AM
