PS5 cut off or freeze on main menu
  • JonnyS
    • Apr 2016
    • 9
    • Poland
    hi
    i have a problem with PS5
    that cut off or freeze on main menu
    i try to rebuild database - not helps
    reinstall software and factory reset - not helps not helps
    can somebody have idea what i can do more ?
    i will be very thankfully.
    kind regards
  • LaPCon_IT
    • Sep 2022
    • 80
    • Malta
    Re: PS5 cut off or freeze on main menu
    How long does it take from powering PS5 on, to the moment it freezes? Try couple of times and check if that time is constant or not.
    • stormanimal83
      • May 2014
      • 74
      i think you got problems with ram... or the connection from apu to ram...
      please visit the youtube channel of Phil TheCoder... he tried several times to repair a console liuke that. he is also the person that made possible to change a disc drive edition with broken disk drive to digital edition to make the console work again....
        • 31015
        or watch him live most nights
        https://www.twitch.tv/thecod3r2015
        • JonnyS
          • Apr 2016
          • 9
          • Poland
          hi
          thanks for a quick answer.
          Time to freeze is not constant but freezing is everytime when i try to run a any game.
          stormanimal83 :i subscribing a the cod3r YT channel but i cant find any similar case
            • 31015
            if you catch his twitch stream you can ask him.
            • stormanimal83
              • May 2014
              • 74
              did u try to insert an additional ssd and run games from there? possible internal ssd fault? from my experiences you could use a cheap crucial p3 plus. i bought one for my pc and wanted to know if the ps5 is recognising it cause it is a bit to slow but still an pciexpress 4 device.... and yes it is... not the fastest ssd u can use but the cheapest possible... my console accepted it. my console has a samsung 980 pro heatsink 1tb normally... i was curious and changed them before i built up the pc...
              Last edited by stormanimal83; 08-01-2023, 09:34 AM. Reason: added pic, corrected typing
                LCD LED TV Service Menu Codes
                ALL LCD LED TV SERVICE MENU CODES
                Service Menu Code with Board Name
                China Universal Board / Jumper Board Service Menu Code
                Changhong Ruba Service Menu Code
                Ecostar LED TV Service Menu Code
                Orient LED TV Service Menu Code
                Haier LED TV Service Menu Code
                TCL LED TV Service Menu Code
                Samsung LED TV Service Menu Code
                LG LED TV Service Menu Code
                Videocon LED TV Service Menu Code
                Supra LED TV Service Menu Code
                Toshiba LED TV Service Menu Code
                Symphony LED TV Service Menu Code
                Veste/ LED TV Service Menu Code...
                10-31-2024, 03:58 AM
              • ygorsan
                by ygorsan
                🧩 Problem Summary:
                • I
                Yesterday, 08:34 AM
              • cheeky2
                by cheeky2
                05-25-2024, 03:27 AM
              • Asraf Atb
                by Asraf Atb
                01-27-2025, 05:02 PM
              • JSin21
                Compatibility of main boards between different variations of samsung MU6100
                by JSin21
                Hoping someone here could possibly help. I have a few questions in regards to compatibility with main boards. But I'll give a quick short run down on what's going on first;
                I have Samsung Smart TV UA65MU6100WXXY version DA01
                Now years ago it started intermittently playing up after a lighting strike. Lighting hit the block of units i was living in at the time. Ever since that night the TV started having a mind of its own, It would randomly turn itself off or on, and all inputs stopped responding like HDMI, aerial, but USB still worked. Anyway, over the next few months...
                11-27-2023, 04:54 AM
