XBOX 360 possible bad caps...
+ More Options
Posts
  • Rob
    • Oct 2005
    • 47
    Over at anandtech they rip apart the xbox 360.... if im correct.. those little yellow ones are usually a problem...
    http://images.anandtech.com/reviews/...al_removed.jpg
  • Rob
    • Oct 2005
    • 47
    Re: XBOX 360 possible bad caps...
    More Cap shots
    http://images.anandtech.com/reviews/...0/heatpipe.jpg
    • willawake
      Super Modulator
      • Nov 2003
      • 8457
      • Greece
      nice find. they can be a problem but not guaranteed. they are not filled with electrolyte but they fail due to manufacturing error which gets moisture inside them.
      regarding the pics i removed the actual pic until mods discuss ongoing issue of pics from other sites. hotlinking does bring webmasters around to see who is hotlinking their pics.
      post a link to the article as well for courtesy purposes.
      • Rob
        • Oct 2005
        • 47
        Sorry... thats why i provided the actual link...
        • willawake
          Super Modulator
          • Nov 2003
          • 8457
          • Greece
          mods discussed and there is no prob. nice to have u here. i try to correct but linx dead.
          • japlytic
            • Oct 2005
            • 2086
            http://www.anandtech.com/systems/showdoc.aspx?i=2610
            Since the 360's power supply is external, it is better than using a special "safety lead" with the original XBOX (It had no fuse -!- in the internal power supply!)
            • willawake
              Super Modulator
              • Nov 2003
              • 8457
              • Greece
              i checked some of the pics around the net. i have seen two versions. One has Nichicon HZ(M), Chemicon and Fujitsu. The other has Rubycon MCZ instead of the Chemicon.
              The probs with the xbox freezing now appear to be due to the external power supply overheating in cases. Once it is raised off the ground, the xbox is stable.
              http://www.gamespot.com/forums/show_...3998153&page=0
              • PeteS in CA
                • Aug 2005
                • 3581
                • USA, Unsure of Planet
                Who makes the P/S? Or did uSoft force the mfr to omit their name and logo? BTW, having one of those small 3-speed fans blowing on the P/S would probably be better than raising the P/S off the floor/table.
                PeteS in CA
                • willawake
                  Super Modulator
                  • Nov 2003
                  • 8457
                  • Greece
                  it is supposed to have 2 fans inside?? who knows who made it.
                  funny to see how much column inches the tech news sites got out of the size of the adapter. the console is pulling max 254 watts what did they expect.
                  get ready for the adaptor case mods............
                  • PeteS in CA
                    • Aug 2005
                    • 3581
                    Well I just did a Google search, hoping to find a pic of the P/S. I was bemused by the almost childish whining on some gamer sites about its size. Are gamers unaware that you cannot pull 200W-250W out of thin air? Sheesh! Oh! And that na-a-a-asty fan! Better the game box should fry itself?!
                    PeteS in CA
                    • RJARRRPCGP
                      • Jul 2004
                      • 6304
                      The links are bad. (error 404)
                      ASRock B550 PG Velocita
                      Ryzen 9 "Vermeer" 5900X
                      Arc A770 16 GB
                      eVGA Supernova G3 750W
                      Alienware AW3423DWF OLED
