PS5 BLOD- CFI-1115A Disc Version- Board= EDM-020
Re: PS5 BLOD- CFI-1115A Disc Version- Board= EDM-020
Update: As a last ditch effort i pulled the New wifi module off to check diode readings without it. All diode readings now match a known good board. Working on getting another wifi module. Stay tuned.Leave a comment:
Resistor was 200k. Still chasing root of problem.Leave a comment:
A2 chip did not rectify the issue. Replaced all caps under wifi module. Some caps on this line are still reading short to ground. Maybe I have a bad wifi module? Not sure where the 3.3v and 5.0v rail are created. Thanks Sony lolLeave a comment:
I am hoping this works per the a2 chip's datasheet. https://www.mouser.com/ProductDetail...G5yjipLg%3D%3DLeave a comment:
maybe if you check the size in mm and then look at inductors at digikey you can get an ideaLeave a comment:
Can you post your dump of your board ? (EDM-020)Leave a comment:
Ordered the replacement for the A2 chip along with fuses. Went with 0402 3a 24v. That was the lowest i could find. Pretty sure its just the chip and the fuse most lilely blew from when i injected voltage.Leave a comment:
The issue Phil has here sounds like my issue now that the southbridge is back to normal. Just watched his vid here tonight. This PS5 may have been trolling me with the Southbridge issue. https://youtu.be/IevHM3oDUvg. Going to follow Phil's troubleshooting and see if we can land this plane haha. Still need the fuse and cap values he replaces here but it's a start.Leave a comment:
well 0402 is a lot smaller than 0603, so get the correct size or soldering it in wont be easyLeave a comment:
either will handle more that a ps5 has in itLeave a comment:
0402 vs 0603 you can check with a vernierLeave a comment:
To be honest i dont know what I need. Just going by what i was told.What would be the best way for me to test. I was also told the fuse is probably a 0402 fast blow. Instead of 0603 slow blow. Frustrating not having a schematic
thats fine if it is 3a you needLeave a comment:
So this would work right?
https://www.digikey.com/en/products/...00-TM/15204247Leave a comment:
Assuming...7 Photos -
by m1ch43lzmHi, this is my personal laptop, which the original board (lets call it Board A) blew up PU8700 (TPS51486), making a hole on the board, i had left the laptop at my desk one day with the battery fully charged and didn't touch it for a week, but when i tried to turn it on it didn't
Thought the battery was dead, so i plugged in the charger then tried to power on, the power LED blinked once, charged LED still orange, unplugged the charger, plugged in again and I noticed the "magic smoke" smell, so i unplugged the charger, removed the back cover and saw the blown IC (the "magic... -
by Junior††
Good Afternoon fellas,
Issue:
Disc is showing as not supported when a disc is put in.
Here's what I've done, you can skip this if you just wanna know the question:
- replaced with a disc drive from a donor ps5 (honestly questionable if this is known to work)
- reflowed the disc drive connector
-reflowed the chip in question (shown on image)
- I will say this console was very dusty so it's conceivable that it got so hot that it made the chip joints cold and potentially other things on the board
Question:
I... -
by howardc64All left and right refers to looking from rear of TV (or looking from front with TV upside down)
- TV came with vertical bars and no image. Found faulty TVS on left buffer board. Also replaced T-Con (may have damaged the original while hot air removing components, board has slight warp) and have full image but few horizontal lines on the screen. Some of the lines appears to be 2 pixel tall while others are 1 pixel tall.
- Disconnecting left and right buffer board potentially reveals problems on both sides with different signals (unless this T-Con require jumper like Samsung FB_TRDY1&3) Fault
by HakuuHi There,
More Details
TV Model - LG OLED77G1PUA
Got the same exact TCON board from TVPartsToday and replaced it. But didnt transfer the EPPROM data (didnt... - Loading...
