PS5 BLOD- CFI-1115A Disc Version- Board= EDM-020
  • TheWizard
    replied
    Re: PS5 BLOD- CFI-1115A Disc Version- Board= EDM-020
    Update: As a last ditch effort i pulled the New wifi module off to check diode readings without it. All diode readings now match a known good board. Working on getting another wifi module. Stay tuned.
  • TheWizard
    replied
    Resistor was 200k. Still chasing root of problem.
  • TheWizard
    replied
    Anyone know the value of this resistor on the 1.8v rail of the edm-020 board? Showed low resistance to ground and want to replace.
  • TheWizard
    replied
    A2 chip did not rectify the issue. Replaced all caps under wifi module. Some caps on this line are still reading short to ground. Maybe I have a bad wifi module? Not sure where the 3.3v and 5.0v rail are created. Thanks Sony lol
  • TheWizard
    replied
    I am hoping this works per the a2 chip's datasheet. https://www.mouser.com/ProductDetail...G5yjipLg%3D%3D
  • TheWizard
    replied
    Originally posted by stj
    maybe if you check the size in mm and then look at inductors at digikey you can get an idea
    Yeah was going down that road. Playing the reference game. Haven't measured the part yet. Will keep you posted.
    replied
  • TheWizard
    replied
    well 0402 is a lot smaller than 0603, so get the correct size or soldering it in wont be easy
    Any idea what the value is of this power inductor?
  • sadenki
    replied
    Can you post your dump of your board ? (EDM-020)
  • TheWizard
    replied
    Ordered the replacement for the A2 chip along with fuses. Went with 0402 3a 24v. That was the lowest i could find. Pretty sure its just the chip and the fuse most lilely blew from when i injected voltage.
  • TheWizard
    replied
    The issue Phil has here sounds like my issue now that the southbridge is back to normal. Just watched his vid here tonight. This PS5 may have been trolling me with the Southbridge issue. https://youtu.be/IevHM3oDUvg. Going to follow Phil's troubleshooting and see if we can land this plane haha. Still need the fuse and cap values he replaces here but it's a start.
    replied
  • TheWizard
    replied
    either will handle more that a ps5 has in it
    Fixing this thing to flip it. I want to get all the right parts lol
    replied
  • TheWizard
    replied
    0402 vs 0603 you can check with a vernier
    Just making sure to match up the voltage because i don't want an arc to happen.
    replied
  • TheWizard
    replied
    thats fine if it is 3a you need
    To be honest i dont know what I need. Just going by what i was told.What would be the best way for me to test. I was also told the fuse is probably a 0402 fast blow. Instead of 0603 slow blow. Frustrating not having a schematic
    replied
  • TheWizard
    replied
    so if it's rated for 250v your fine.
    fuses dont blow based on voltage - only the current matters
    So this would work right?
    https://www.digikey.com/en/products/...00-TM/15204247
  • TheWizard
    replied
    Exactly "stj".
    Diif, Sorry was a horrible picture after the downsize for upload. I snapped a new one. Here you go. "T"
  • m1ch43lzm
    by m1ch43lzm
    05-12-2025, 08:37 PM
  • Junior††
    PS5 Disc Not Supported/ Disc Not Recognized Board Num: EDM-020
    by Junior††
    Good Afternoon fellas,
    Issue:
    Disc is showing as not supported when a disc is put in.
    Here's what I've done, you can skip this if you just wanna know the question:
    - replaced with a disc drive from a donor ps5 (honestly questionable if this is known to work)
    - reflowed the disc drive connector
    -reflowed the chip in question (shown on image)
    - I will say this console was very dusty so it's conceivable that it got so hot that it made the chip joints cold and potentially other things on the board
    Question:
    I...
    02-19-2025, 12:48 PM
  • howardc64
    by howardc64
    07-24-2025, 05:17 PM
  • Hakuu
    by Hakuu
    Hi There,
    More Details
    TV Model - LG OLED77G1PUA
    07-12-2023, 02:37 PM
