Ps5 three beeps when plugged in, no life
  • crea2k
    • Oct 2016
    • 28
    • United Kingdom
    Hi I've got a ps5 in for repair. When it's plugged in it immediately beeps three times.
    On the desktop power supply it pulls no current.
    Under thermal camera nothing shows up.
    All fuses test good
    Voltages are :
    F7002 - 5v
    F7502 - 5.1v
    F7003 - 5.1v
    F5402 - 12v
    F5401 - 0.18v
    F3501 - 12v
    F7001 - 5.1v
    So presuming the issue is in the F5401 circuit.
    I have probed it and see no shorts in the 5 components there. So not sure where to go from here as no idea what does what in that circuit other than the fuse and cap or what voltage it should be ?.
  • crea2k
    • Oct 2016
    • 28
    • United Kingdom
    Re: Ps5 three beeps when plugged in, no life
    Fixed the issue !, here’s the video https://youtu.be/QU10tf1dIzk
    • Rambonz
      • Mar 2023
      • 11
      • new zealand
      I was under the impression that on the disc editions, the bios contain the pairing keys with the daughter board. Did you flash it with a disc edition bios you found online or were you able to back it up and reflash first? otherwise, you would run into errors when trying to run a disc?
      correct me if I'm wrong
      • aktinson
        PS Lover
        • May 2023
        • 18
        • Bulgaria
        It's great to hear that you were able to solve the issue with the three beeps on your PS5. The video you shared was very helpful in demonstrating how to fix the issue.
        Regarding Rambonz's comment, they are correct that the BIOS on the disc editions of the PS5 contain the pairing keys with the daughter board. It's important to make sure that the BIOS you flashed is the correct one for your specific PS5 model to avoid any errors when trying to run a disc.
        If you didn't backup your original BIOS before flashing a new one, it's recommended to do so in case any issues arise in the future. It's always better to be safe than sorry when it comes to these things.
        I hope this information helps, and happy gaming!
        • Xwalt
          • Apr 2023
          • 7
          • UAE
          Originally posted by crea2k
          Fixed the issue !, here's the video https://youtu.be/QU10tf1dIzk
          How did you get the bios file? mind sharing it?
          • lotas
            • Jan 2016
            • 4537
            • Russia
            There is a link to the firmware in the comments.
            • Vila_666
              • Sep 2023
              • EspaƱa
              Anyone has the files?
              Comment link is down.
              • ChocoboGS
                • Aug 2023
                • 7
                • Indonesia
                Anyone have a bios for CFI-1100?
