I have dualshock 4 controller that works fine except for the fact that after being plugged in to a pc or ps4 and then unplugged the PS button stops responding, ie. you get no white flashing as if the controller is completely dead. the only thing you can do to remedy it is to use the reset button on the back at which point the PS button starts to function correctly again and even allows you to use the SHARE and PS button to connect to a pc and play games however if you plug it even for a second in a pc or ps4 the next time you try to turn on the controller it does nothing, to me it seems like a possible firmware issue but not sure. Even if you plug in the controller while it is paired to a pc via bluetooth you won't be able to turn the controller off by holding the PS button for 10seconds as if the PS button completely breaks
Any ideas? Thanks in advance!
