How to test circuit board battery connection.RS-4i sequential stimulator
  • Crrose
    • Dec 2013
    • 165
    • Usa
    Not sure where to post this but I have an RS-4i sequential stimulator that runs off rechargeable batteries and also has a VL2330 coin cell battery that retains the memory. If that battery doesn't hold charge or connection is bad then the unit will power on and say to recharge. Once it is charged it indicates it is charged but when you turn unit on it powers off saying to charge batteries. I replaced that coin cell battery and now it won't even indicate batteries need to be charged. I have tested the battery pack and it is fully charged at 6V but the coin cell only shows 2.97V which is a brand new battery I put in. It will not charge any higher and machine will not even turn on any longer.
    I tested to pins and legs on both sides of the circuit board and it shows the power of the coin cell. When I put the new battery in I just cut of the solder tabs oh the old battery so I wouldn't mess up the circuit board and soldered the new battery legs to the old battery legs.
    So shouldn't there be continuity between the 2 solder joints on the circuit board?
  • CapLeaker
    Leaking Member
    • 8120
    Re: How to test circuit board battery connection.RS-4i sequential stimulator
    What are you talking about? Continuity between what solder joints? It’s hard to picture something, one hasn’t got a picture off! Take some high resolution straight shot pictures and post them using the attachment function.
    • Crrose
      • Dec 2013
      • 165
      • Usa
      Here are some pictures, put new battery in and still won't come on.
      • Devil_rider
        • Jan 2023
        • 33
        Br2330 is not rechargeable and most likely there is no charging circuit so do not expect the voltage to increase on it.I can see couple of regulators , do they get voltage? Is the power button connected to processor ? Does the processor have power?
        • CapLeaker
          Leaking Member
          • 8120
          Hmm… the VL2330 is a rechargeable battery. The BR2330 is single use only. So you put a non rechargeable battery into a rechargeable situation. That’s not that good.
          The battery should be for memory backup only. So the device should work without in, if it’s plugged it. If nothing is working, the must be something wrong somewhere. Hopefully it is something simple like a missing voltage somewhere .
          • Crrose
            • Dec 2013
            • 165
            • Usa
            Hmm I replaced with the VL2330 because I thought it was the same size being 2330 and it had the legs on it so it could be soldered on the board. I'll try looking for a BR2330 and try that. But shouldn't it still work being a 3v coin cell even thought it can't be recharged?
            • Crrose
              • Dec 2013
              • 165
              • Usa
              This is the original recall letter I got years ago.
              • CapLeaker
                Leaking Member
                • 8120
                Interesting piece of information. Usually things work fine without the backup battery, but I guess this unit turns off when the battery is depleted.
                In your case a 3V coin cell battery is nearly dead if it measures 3.00V. Yours is 2.97V, so I'll call it almost dead.
                How long did this device take to drain the new battery?
                Question is what does the backup battery have for an exact function in order to render the unit useless when the battery is dead. Does this mean a chip lost some sort of programming and is in need of reflashing too? There were some other old devices that had the same problem. Backup battery dead, meant everything stayed dead because it lost its programming.
                Looking at the TMS230LF2406A datasheet I see a boot enable pin. Maybe it has to do with something or not. I guess you can figure that out by checking the voltage on it (no battery vs with battery installed).
                • Crrose
                  • Dec 2013
                  • 165
                  • Usa
                  I've tried 2 different LV2330 batteries and both came charged at only 2.97v so I don't know if being a rechargeable battery in a unit that does not use a rechargeable would make it not work still or if like you said since battery is below 3v it is considered dead. Neither battery worked in the unit. I don't know why I assumed it was a rechargeable battery other then me reading the recall wrong. Trying to find a BR2330 with solder pins that will fit and see if that will do it.
                  • CapLeaker
                    Leaking Member
                    • 8120
                    We here have terrible times getting certain coin cell batteries, thanks to our government not allowing lithium cells to be transported in cargo airplanes. So I resorted into fitting coin cell holders from old motherboards and slip a something more common in there whatever fits.
                    For testing purposes, you can put a single use, non rechargeable battery in there, just don’t leave it in there, since it can swell up and cause damage.
                    • Crrose
                      • Dec 2013
                      • 165
                      • Usa
                      apparently it supposed to have a single use battery not rechargable, that's why i'm looking for a br2330 with solder pins. The battery was replace once for the recall and the one they put in lasted probably 7 years with very little use of the machine. Where is the boot up pin?
                      • CapLeaker
                        Leaking Member
                        • 8120
                        Just google the chip with data sheet on the end. Post #8
                        • Crrose
                          • Dec 2013
                          • 165
                          • Usa
                          I can't figure that data sheet out. Could I just install a button cell holder instead of trying to find that battery with solder pins?
                          • CapLeaker
                            Leaking Member
                            • 8120
                            That’s what I would be doing for testing purposes only. Put a regular cr2032 battery and holder in there and see what it does. Measure the 2032 before you put it in and see what happens.
                            • Crrose
                              • Dec 2013
                              • 165
                              • Usa
                              Now I just need to find a holder that will hold a BR2330 since it is larger then the CR2032..I don't want to keep soldering the board and taking a chance of messing it up.
                              • CapLeaker
                                Leaking Member
                                • 8120
                                Not sure if there is such thing
                                • Crrose
                                  • Dec 2013
                                  • 165
                                  • Usa
                                  They do have them but I don't want to buy 500 of them, guess they sell them to people who make circuit boards.
                                  • Ancient1
                                    MacBook Pro 2012 A1398 : Battery BMS circuit repair OR can it boot WITHOUT a battery ?
                                    by Ancient1
                                    Hi
                                    I received such Laptop as junk. Opening it I saw a lot of whitish water residue , but no corrosion really ( few coils have small brown rust marks, no green copper ).
                                    I cleaned all thoroughly and interestingly , its the Battery BMS board that has the real corrosion spots.. under the protective clear Goo !!
                                    I want to try and power up the laptop
                                    Battery is swollen. But I don't want to buy a new battery right now , of course .
                                    I started work on the BMS by zooming in on green spots . 2 VIAs are filled with rusted copper goo - who knows...
                                    04-17-2024, 12:46 AM
                                  • Bowline
                                    by Bowline
                                    06-11-2025, 10:13 AM
                                    NVDC charger configuration...
                                    11-05-2024, 03:28 PM
                                  • huzo
                                    HP ELITE X2 1013 G3 weird battery issue
                                    by huzo
                                    Hi, so the old battery was getting error stated it's capacity is starting too get low and should be replaced, so the customer bought a new one and replaced it, but the new battery was also getting this notice that it's capacity is getting low and should be replaced, so i took the laptop for testing and the battery is charging at the terminal at 8.03V , the voltage of the battery is 7.7V, and drawing around 600mA when charger is put and the laptop is off...so that should be ok... but the bios system test doesn't recognize the battery and can't do the battery test and so is the hp battery manager,...
                                    01-31-2025, 12:09 AM
                                  • trepachka
                                    iPad Air A1475 Boot loops after replacing battery
                                    by trepachka
                                    This iPad was working fine except the battery was not holding charge for more than 40 minutes. I replaced it with a new battery. I haven't glued the battery yet, just inserted it into the slot and held it with battery screw.
                                    The iPad was powered on with the new battery and I am getting white screen with Apple logo for about 10 seconds, then the screen turns dark. It then cycles like this forever.
                                    I know the battery is working because the iPad continues to boot loop without the charger until it depletes to 0% and the message displays I need to plug in the charger.
                                    11-08-2024, 03:17 PM
