Xbox One S - need PSU schematic and boardview
  • survivalbloke
    • Aug 2021
    • 314
    I've got an Xbox One S PSU opened up. I'm not getting 12vdc output as I do with my test unit. I'm sure this board must have a fuse but I don't see it as everything on the board is poorly labeled.
    • 31296
    Re: Xbox One S - need PSU schematic and boardview
    post a picture - i dont think there is only one type
    as for a fuse, look for a small box like a polyester capacitor but brown
    • survivalbloke
      • Aug 2021
      • 314
      imgur
      Thanks! What's the rectangular component which is in the lower right area on the last pic? It has two connections, is black in the middle and greenish around its edges?
      Thanks!
        • 31296
        stupid site makes the pictures SMALLER when i click on them!
        the green part is a resistor,
        the fuse is gray and in the corner where the connector is soldered.
        you can see one of the wires connects directly to one end
        • survivalbloke
          • Aug 2021
          • 314
          Gosh, what an AWFUL picture. I'm confused and will take another, clear pic, under my scope so you can point out the fuse. I do see something in that corner, but it doesn't look soldered directly. It looks like it could possible be soldered to the same trace.
          • diif
            • Feb 2014
            • 6978
            • England
            Click Go Advanced below and then the paperclip to add them here.
              • 31296
              you dont need a microscope, just follow the tracks from the socket wires
              • lotas
                • Jan 2016
                • 4903
                • Russia
                In order not to search for a long time, I will make the task easier.
                • survivalbloke
                  • Aug 2021
                  • 314
                  I was just about to post another pic - but of the opposite side. OK, so that's a fuse for the AC side, I wasn't thinking like that. My mind is always in motherboard diagnostic mode. and this is the first time I've ever dabbled with PSU's. Now I get it - thanks!
                  **30sec later** Welp, fuse is good. I'm out of ideas lmao.
                  • survivalbloke
                    • Aug 2021
                    • 314
                    If anyone knows common faults of this unit, I'm all ears. The fuse is good. I'm about a 5-6 on motherboard diagnostics but know nothing about PSU diagnostics. I've found a lot of info online about the Xbox One, but can't seem to find any info on the One S.
                      • 31296
                      if the fuse is good there are 2 common psu problems - not specific to this one.
                      first - shorted output diode.
                      so meter between the 12v and ground contacts
                      second - but i dont thing its old enough, although it is in a sealed box, the small startup capacitor that gets the chip running.
                      it's going to be an electrolytic connected to the chip with a value between 10uf and 47uf usually.
                      if it fails the psu cant start
                      • survivalbloke
                        • Aug 2021
                        • 314
                        You're awesome! the 12V rail is shorted to ground. Using voltage injection I can see two components heating up. In this picture, that resistor is the first to boil off but right after, that component marked K401 boils off, so I'm imagining it's the K401? What type of component is that?
                        • R_J
                          • 9627
                          K401 seems to be a TS321IL
                          • survivalbloke
                            • Aug 2021
                            • 314
                            Thank you. Did you just google 'K401'? If so, I'm going to feel dumb. So that's an operational amplifier. I removed it from the board and the short is gone. I'll get that ordered up. Thanks to all of you!
                              • 31296
                              is that ceramic cap top-right even soldered down properly?
                              • survivalbloke
                                • Aug 2021
                                • 314
                                Yes, just a bad camera angle.
                                • nicole77
                                  Looking for Boardview file for Xbox One S, Series S and also Series X, Please
                                  by nicole77
                                  01-15-2025, 04:50 AM
                                • mard312
                                  Legion Go 8APU1 boardview or schematic
                                  by mard312
                                  I’m working on repairing a Lenovo Legion Go that suffered liquid damage. Unfortunately, one of the ICs on the motherboard burned out, and I haven’t been able to find any boardview or schematic for this model anywhere.
                                  Does anyone happen to know what this particular chip is, or have access to the schematic/boardview for this motherboard? Any help or reference would be greatly appreciated.
                                  11-12-2025, 01:01 PM
                                • AustinCER
                                  In Search of Schematic/Boardview for Lenovo Ideapad Flex 5 14ALC7
                                  by AustinCER
                                  I am in search of a schematic or boardview for Lenovo Ideapad Flex 5 14ALC7.
                                  No power and no charging LED with AC Adapter connected. AC Adapter is functioning at 19V, and also tried another Lenovo AC Adapter -- no charging LED still.
                                  There is an active 19V from the USB-C port to the motherboard with AC Adapter connected, so the port is also fine. I am assuming there is a short on one of the power rails, but don't know where to start looking.
                                  Any insight, schematic or boardview would be greatly appreciated.
                                  Model: Lenovo Ideapad Flex 5 14ALC7...
                                  11-04-2025, 03:49 PM
                                • PacoGT
                                  HP ENVY x360 gidget 8L 203038-1, boardview and schematic need
                                  by PacoGT
                                  hello firends
                                  i search the schematic or boardview
                                  I have this motherboard, but I can't find the schematic or the boardview.
                                  The problem is that on the chip marked where 3V should be, there are 5 volts, which indicates that the two are connected.
                                  So the computer doesn't turn on, and the 3V disappears after a few seconds.
                                  The original problem was that when I turned off the computer, the fan stayed on and saw that it was bad since it was directly in the 5V area.
                                  The new problem arose after removing the bad chip.
                                  3V and 5V remained together,...
                                  08-19-2025, 08:25 PM
                                • hosain0489
                                  Request for Schematic and Boardview for HP Omen 16-xf0006AX (AMD Ryzen 7 7840H Version)
                                  by hosain0489
                                  I’m looking for the schematic and boardview files specifically for the AMD version of the HP Omen 16 laptop, model xf0006AX, equipped with the Ryzen 7 7840H CPU.
                                  Most of the files I’ve found are for Intel CPU versions, and I need the exact files for this AMD Ryzen 7 7840H model to assist with repair and troubleshooting.
                                  If anyone has access to these files or can kindly share the boardview and schematic for this particular AMD version, I would really appreciate your support.
                                  Thank you very much in advance!
                                  07-15-2025, 11:20 AM
