Xbox One S - need PSU schematic and boardview
  • survivalbloke
    • Aug 2021
    • 278
    I've got an Xbox One S PSU opened up. I'm not getting 12vdc output as I do with my test unit. I'm sure this board must have a fuse but I don't see it as everything on the board is poorly labeled.
    • 30979
    Re: Xbox One S - need PSU schematic and boardview
    post a picture - i dont think there is only one type
    as for a fuse, look for a small box like a polyester capacitor but brown
    • survivalbloke
      • Aug 2021
      • 278
      imgur
      Thanks! What's the rectangular component which is in the lower right area on the last pic? It has two connections, is black in the middle and greenish around its edges?
      Thanks!
        • 30979
        stupid site makes the pictures SMALLER when i click on them!
        the green part is a resistor,
        the fuse is gray and in the corner where the connector is soldered.
        you can see one of the wires connects directly to one end
        • survivalbloke
          • Aug 2021
          • 278
          Gosh, what an AWFUL picture. I'm confused and will take another, clear pic, under my scope so you can point out the fuse. I do see something in that corner, but it doesn't look soldered directly. It looks like it could possible be soldered to the same trace.
          • diif
            • Feb 2014
            • 6978
            • England
            Click Go Advanced below and then the paperclip to add them here.
              • 30979
              you dont need a microscope, just follow the tracks from the socket wires
              • lotas
                • Jan 2016
                • 4554
                • Russia
                In order not to search for a long time, I will make the task easier.
                • survivalbloke
                  • Aug 2021
                  • 278
                  I was just about to post another pic - but of the opposite side. OK, so that's a fuse for the AC side, I wasn't thinking like that. My mind is always in motherboard diagnostic mode. and this is the first time I've ever dabbled with PSU's. Now I get it - thanks!
                  **30sec later** Welp, fuse is good. I'm out of ideas lmao.
                  • survivalbloke
                    • Aug 2021
                    • 278
                    If anyone knows common faults of this unit, I'm all ears. The fuse is good. I'm about a 5-6 on motherboard diagnostics but know nothing about PSU diagnostics. I've found a lot of info online about the Xbox One, but can't seem to find any info on the One S.
                      • 30979
                      if the fuse is good there are 2 common psu problems - not specific to this one.
                      first - shorted output diode.
                      so meter between the 12v and ground contacts
                      second - but i dont thing its old enough, although it is in a sealed box, the small startup capacitor that gets the chip running.
                      it's going to be an electrolytic connected to the chip with a value between 10uf and 47uf usually.
                      if it fails the psu cant start
                      • survivalbloke
                        • Aug 2021
                        • 278
                        You're awesome! the 12V rail is shorted to ground. Using voltage injection I can see two components heating up. In this picture, that resistor is the first to boil off but right after, that component marked K401 boils off, so I'm imagining it's the K401? What type of component is that?
                        • R_J
                          • 9535
                          K401 seems to be a TS321IL
                          • survivalbloke
                            • Aug 2021
                            • 278
                            Thank you. Did you just google 'K401'? If so, I'm going to feel dumb. So that's an operational amplifier. I removed it from the board and the short is gone. I'll get that ordered up. Thanks to all of you!
                              • 30979
                              is that ceramic cap top-right even soldered down properly?
                              • survivalbloke
                                • Aug 2021
                                • 278
                                Yes, just a bad camera angle.
