Asus Prime B450m-K bios dump
Re: Asus Prime B450m-K bios dump
Download the bios from the support page,extract from the zip folder then open the *.CAP with UEFITool , select "Action - Capsule - Extract Body" that will remove the CAPsule header leaving you with the 16,384KB 16MB bios .Rename it from *.ROM to *.bin if you like, its the same thing.
UEFITool https://github.com/LongSoft/UEFITool..._A57_win32.zip
Asus PRIME-B450M-K support https://www.asus.com/motherboards-co...=PRIME-B450M-K -
Off topic,this thread is for the B450m-K .Get your bios from Asus support,then read post 2 ,you can extract it yourself. https://www.asus.com/motherboards-co...RIME-B460-PLUS
Asus PRIME-B450M-K support https://www.asus.com/motherboards-co...=PRIME-B450M-KComment
by DynaxSCHi,
Usually on ASUS boards it worked...-
by razor_amdWith ASUS, not everything is quite so simple. I will show you my way. It may be longer or harder but it is the right way to do it in my humble opinion.
This is the picture of 3 similar ASUS motherboards, all of them being X555LD...-
Channel: BIOS Requests ONLY!
by reset1986Hi guys, I have this PC that does not display an image, video card and GPU and RAM are working, tested on another PC, I suspect the BIOS is damaged, I attach the original dump, I need a working BIOS, thanks...
by AhariHi all,
I...-
by jbonavitaHi, my laptop wont boot at all
Some issues
Things I tried
1- Update / clear ME: Took the non working bios, made a backup, and did this: https://www.badcaps.net/forum/troubl...theory/trouble...-
- Loading...
