Asus Prime B450m-K bios dump
  • cemsancar
    • Oct 2014
    • 5
    • Turkey
    • 21467
    Re: Asus Prime B450m-K bios dump
    Download the bios from the support page,extract from the zip folder then open the *.CAP with UEFITool , select "Action - Capsule - Extract Body" that will remove the CAPsule header leaving you with the 16,384KB 16MB bios .Rename it from *.ROM to *.bin if you like, its the same thing.
    UEFITool https://github.com/LongSoft/UEFITool..._A57_win32.zip
    Asus PRIME-B450M-K support https://www.asus.com/motherboards-co...=PRIME-B450M-K
    • cemsancar
      • Oct 2014
      • 5
      • Turkey
      thanks very very Thanks
      • shakthi
        • Sep 2023
        • New Zealand
        asus prime B460-plus R1.03
        CL-2 ru 94V-0
        E241819
        bios .bin Please
          • 21467
          CL-2 ru 94V-0
          E241819
          bios .bin Please
          Off topic,this thread is for the B450m-K .Get your bios from Asus support,then read post 2 ,you can extract it yourself. https://www.asus.com/motherboards-co...RIME-B460-PLUS
          • babarali
            • Jun 2023
            • 13
            • Pakistan
            CL-2 ru 94V-0
            E241819
            bios .bin​
            • azou
              • Jun 2016
              • 15
              • alger
              Thank you ... thank you
              • DynaxSC
                by DynaxSC
                06-14-2024, 03:49 PM
              • razor_amd
                by razor_amd
                12-15-2020, 07:07 PM
              • reset1986
                Asus prime b550m-a bios dump
                by reset1986
                Hi guys, I have this PC that does not display an image, video card and GPU and RAM are working, tested on another PC, I suspect the BIOS is damaged, I attach the original dump, I need a working BIOS, thanks...
                06-22-2025, 04:17 AM
              • Ahari
                by Ahari
                I...
                08-13-2025, 06:12 AM
              • jbonavita
                by jbonavita
                Some issues
                Things I tried
                04-29-2025, 09:38 PM
