Hi guys, I have this PC that does not display an image, video card and GPU and RAM are working, tested on another PC, I suspect the BIOS is damaged, I attach the original dump, I need a working BIOS, thanks
Asus prime b550m-a bios dump
by DynaxSCHi,
Usually on ASUS boards it worked...-
by mkdjDear all,
I would appreciate if someone could take time to explain the issue, so that I can learn. But I would...-
Channel: BIOS Requests ONLY!
by razor_amdWith ASUS, not everything is quite so simple. I will show you my way. It may be longer or harder but it is the right way to do it in my humble opinion.
This is the picture of 3 similar ASUS motherboards, all of them being X555LD...-
by AhariHi all,
I...-
by jbonavitaHi, my laptop wont boot at all
Some issues
Things I tried
1- Update / clear ME: Took the non working bios, made a backup, and did this: https://www.badcaps.net/forum/troubl...theory/trouble...-
- Loading...
