BIOS BIN ASUS ROG STRIX B450-i
  • foulou0238
    • Mar 2014
    • 109
    • France
    Hello
    some one can share with me please the bin bios for motherboard
    ASUS STRIX B450-I Gaming
    I can't find it please thank you in advance
    regards
    • 21850
    Re: BIOS BIN ASUS ROG STRIX B450-i
    Originally posted by foulou0238
    Hello
    regards
    Download any bios version from asus support https://rog.asus.com/uk/motherboards...helpdesk_bios/
    Open the bios with UEFITool ,right click on "AMI Aptio capsule" and select "Extract body" .That will remove the 2KB CAP header.Save the file as *.rom or *.bin
    UEFITool - https://github.com/LongSoft/UEFITool..._A57_win32.zip
    • foulou0238
      • Mar 2014
      • 109
      • France
      Hello
      thank you for replay
      already try that but the motherboard only rgb lighting but nothing else ??
        • 21850
        Tpu fw.
        • cacla
          • Apr 2015
          • 444
          Here
          • foulou0238
            • Mar 2014
            • 109
            • France
            Originally posted by cacla
            Here
            thank you so much will test and report here
            • foulou0238
              • Mar 2014
              • 109
              • France
              hello
              i try this file and no poste .
              mobo start normaly win switching on but no display and no led from keyboard
              try with 2 cpu RYZN 5600 and RZN 3600x
              any suggest ?
              • razor_amd
                by razor_amd
                12-15-2020, 07:07 PM
              • grimacelord
                by grimacelord
                07-10-2025, 02:52 PM
              • Technodoc
                ASUS G614JZ G634J-PMV-VGT Rog Strix need some bios help, laptop black screen
                by Technodoc
                Asus laptop G614JZ-N3012W Rog Strix with i7
                Mainboard G634J-PMV-VGT
                6050A3441302-MB-A01
                2023-02-10
                Power button works okay....power light goes on
                Red "bottom" leds go on
                Charging led works
                Fans do not spin, capslock key does nothing, screen stays black
                I would like to program the bios again, to rule out a corrupted bios.
                However I run into a size error
                The bios chip is a Winbond 25R256JVEN
                Used my Xgecu T-48 to read the bioschip (using select chip as type XM25QH256B @WSON8, read somewhere...
                02-24-2025, 04:46 AM
              • LtCdrData
                ASUS Rog Strix 6050A3441302-MB-A01 BIOS
                by LtCdrData
                I'm trying to flash the bios chip but all the files on the asus website end in a 3 digit bios number. I'm not sure how to convert/trim/extract from these files to a file I can load with AsProgrammer to write to the chip.
                ASUS Rog Strix Scar G18 G834JY-XS97
                latest version 331 or oldest 317 would be great. thanks!
                https://rog.asus.com/us/laptops/rog-...helpdesk_bios/
                09-16-2025, 06:13 PM
              • glovecaps
                by glovecaps
                11-25-2024, 04:23 PM
