Dell Wyse 3030 thin client bios
  • salawayon
    • Nov 2012
    • 578
    • philippines
    got a unit with bios password. i attached my backup.
    board info: 6050A2655101-MB-A02
    thanks...
  • hoaca388
    Badcaps
    • Jan 2022
    • 12322
    Re: Dell Wyse 3030 thin client bios
    What's your suffix ?
    • salawayon
      • Nov 2012
      • 578
      • philippines
      there's none... it just ask for a password.. even if i enter an invalid password for a number of times it just keep on asking for a password...
        • 21845
        https://www.badcaps.net/forum/showpo...04&postcount=3 Fireport
        • salawayon
          • Nov 2012
          • 578
          • philippines
          Originally posted by SMDFlea
          thank you very much.. it's working... even removing nor changing the password it will go back to default password as you SET THE BIOS SETTINGS TO DEFAULT...
          • zenius
            by zenius
            12-08-2024, 06:13 AM
          • mikeybass
            by mikeybass
            04-23-2025, 04:30 PM
          • capoplays
            Help with BIOS update on Dell G15 5515 after chip replacement
            by capoplays
            Hey everyone,
            I recently bought a Dell G15 5515 with an AMD Ryzen 7 5800H and 3060 RTX. The BIOS chip on it was dead, and my hardware guy replaced the chip. After that, everything was working fine.
            The BIOS is currently at version 1.22.1, and I wanted to update it. I downloaded the latest BIOS version from Dell Support using my ST: FQZMYJ3, but when I tried to run it, it says "unsupported system." I asked my tech guy what he did, and he said he took the chip from another board and flashed it onto mine.
            When I check the BIOS using the F12 menu Flash...
            10-24-2025, 06:53 AM
          • Akhlz001
            by Akhlz001
            09-20-2025, 07:15 PM
          • jhanra
            by jhanra
            in windows 11 sound driver compatibility, but overall its ok, for me i can deal with it, 😅😅😅...
            11-02-2024, 04:19 AM
