Asus Prime Z690-P D4 BIOS
  • max_sneka2
    • Mar 2022
    • 81
    • iraq
    Hello Every One
    I need Bin File For Asus Prime Z690-P D4 Urgently .... please
    Here Is Old one
    • 21058
    Re: Asus Prime Z690-P D4 BIOS
    Originally posted by max_sneka2
    Hello Every One
    The bios is available at the support site
    https://www.asus.com/Motherboards-Co...HelpDesk_BIOS/
    The bios has a CAPsule header that needs deleting,and the 8 and 16MB are joined together as one file,so it will need editing and splitting with a hex editor: https://mh-nexus.de/en/hxd/
    Open the downloaded bios with HxD.Select "Edit" -> "Select Block" and enter 0 as the "Start-offset" and "FFF" as the "End-offset" ,or set the "Start-offset" as 0 and enter 1000 as the "Length" .Select "Edit" -> "Delete" or press the Del/Delete key on your keyboard.
    Next,select "Edit" -> "Select block" again,enter 0 as the "Start-offset" and 800000 as the length (8 hundred thousand is 8MB) .
    Select "Edit" -> "Cut" . Click on "New" then select "Edit" -> "Paste-insert" or you can right click and select "Paste-insert" .
    Save the file as 8MB.bin and close the tab.Save the remaining 16MB bios (the length of the file is 1 million, 16MB) and rename the file with a *.bin or *.rom file extension
    • Ghost MSM
      Ghost MSM commented
      Editing a comment
      thx for help
  • max_sneka2
    • Mar 2022
    • 81
    • iraq
    Thank You very much ... it works fine but no NVME detected !!!
    Last edited by piernov; 09-10-2022, 01:32 PM. Reason: remove full quote of previous post
      • 21058
      Have you installed the Intel Rapid Storage Technology Driver
      • max_sneka2
        • Mar 2022
        • 81
        • iraq
        i didnt install any thing ... its just not detecting any nvme
        • topkman
          • Dec 2016
          Thank you for nice description, very helpfully.
          • Ayaz Lalani
            • Nov 2024
            • Kenya
            I run these exact same steps and I get these errors when I run the 8MB file through ME Analyzer
            Error: Firmware is incomplete/corrupted, expected 0x1800000 not 0x800000!
            Error: Unsupported Intel Engine, Graphics and/or Independent firmware!​
            I'm trying to modify the 2214 bios version
            Any suggestions?
              • 21058
              Any suggestions?
              The full bios code is split across both chips. MEAnalyzer will detect the bios ok if both files are joined together
              • nissimezra
                • 177
                Many thanks, it worked.
                attached the files
                • varooo
                  • Feb 2025
                  • 3
                  • LA PAZ
                  Please, I beg you, I need help, I've already tried thousands of files, I did the same thing you said and my PC won't start, I put some .bin files in and it just turns on without giving me video, I'm very worried and desperate, I beg you, I implore your help.
                  From what I understand it has 2 chips and I already have the BIOS reprogrammer so I tried many times and I can't solve it.
                  Once it worked for me and gave me video but the PCIe and the M.2 slot didn't work for me and I decided to keep trying.
                  I WOULD REALLY APPRECIATE YOUR HELP..... :"(
                  • peste
                    • Dec 2016
                    • 12887
                    • ROMANIA
                    post S/N, full name and model, motherboard model, post the contents of the bios chip even if it is corrupted..,etc.
                    • varooo
                      • Feb 2025
                      • 3
                      • LA PAZ
                      I have the ASUS PRIME Z690-P WIFI D4 board and in the image I describe the corresponding chips, what software I can use for those 2 chips and I have the CH341A programmer.
                      The PC turns on and doesn't give me an image and the fans sound loudly and then slowly, seeming like it wants to start but it continues in that loop.​
                      • varooo
                        • Feb 2025
                        • 3
                        • LA PAZ
                        The motherboard just gave me video, and I updated the BIOS from a USB with FlashTool from the BIOS, the only problem I have is that it is not recognizing the PCIe ports or the M.2 ports on the motherboard, does it have something to do with reprogramming any of the chips?
                        • razor_amd
                          by razor_amd
                          12-15-2020, 07:07 PM
                        • grimacelord
                          by grimacelord
                          07-10-2025, 02:52 PM
                        • DynaxSC
                          by DynaxSC
                          06-14-2024, 03:49 PM
                        • jbonavita
                          by jbonavita
                          Some issues
                          Things I tried
                          04-29-2025, 09:38 PM
                        • throwaway327
                          by throwaway327
                          Model No: RC72LA
                          Serial No: SBNVKD001014459
                          06-18-2025, 05:52 PM
