B85m-e rev 1.02 chassis intrude error
  • OKRPKCOMP
    • Dec 2020
    • 439
    • PAKISTAN
    Asus board B85M-E bios is ok, motherboard is ok, everything is fine but i am facing this error at startup
    Chassis intrude,pls check yours system
    Fatal error, system halted
    Remember, there is nothing in bios setup to disable chassis error. Anybody can help me to solve this prob
    Thanks in advance
  • OKRPKCOMP
    • Dec 2020
    • 439
    • PAKISTAN
    Re: B85m-e rev 1.02 chassis intrude error
    • hoaca388
      Badcaps
      • Jan 2022
      • 12354
      Asus B85M-E
      • OKRPKCOMP
        • Dec 2020
        • 439
        • PAKISTAN
        Originally posted by hoaca388
        Asus B85M-E
        Sir its only new bios from site, which i already have and tried it
        I need to remove chassis error
        Can u edit bios that it wouldnt show chassis error????
        • hoaca388
          Badcaps
          • Jan 2022
          • 12354
          No, i don't think that's bios error.
          • OKRPKCOMP
            • Dec 2020
            • 439
            • PAKISTAN
            Sir, u r rite, its not a bios error
            but this error can be disable in bios
              • 22009
              It isn`t a bios problem,it could be a bad transistor,its next to the blue jumper.
              A similar problem on an old asus board here https://www.badcaps.net/forum/showthread.php?t=32502
              • OKRPKCOMP
                • Dec 2020
                • 439
                • PAKISTAN
                Problem solved
                There was 3.3 volt missing from chassis jumper to nearly existence 10k
                • Sus256
                  HISENSE 65E7KQ PRO - no boot
                  by Sus256
                  Hi all!
                  HISENSE 65E7KQ PRO
                  RSAG7.820.13512 - chassis
                  MT9618BAATAB - cpu
                  RSAG7.820.12059 - power
                  HD650Y3U77 - panel
                  KLM8G1GETF - emmc
                  The TV does not turn on, the standby indicator is on. All voltages are present.
                  Emms is dead. Not readable, not detected.
                  Replaced emmc.
                  But with another dump there is no launch
                  Terminal log
                  UART
                  AC_ON
                  RPMB key is not yet programmed
                  HASH1_VERSION=0x00000000 64bit
                  E-B
                  FDE enabled
                  layout pattern onebin by SAR7,0...
                  06-01-2025, 02:11 AM
                • sushilachuthan
                  APC UPS error P13
                  by sushilachuthan
                  one of our new (only 4 year old) 1KVA APC UPS stop working and through error P13 contact customer support.
                  the equipment is out of warranty , upon investigation, we found the inverter board has the fault on the output hybrid relay circuit.
                  The inverter output relay is parallel by SCR/Triac to enhance the relay performance or other means.
                  We replaced the SCR with new device,, but the device is not power on as expected.
                  Further research on the issue found that, the error P13 (event ID 107) is latched on the UPS nvram/MCU and need to clear/reset using a service procedure....
                  09-26-2025, 09:00 AM
                • Superbee_dad
                  Sharp 80” long short flash backlight error - Help
                  by Superbee_dad
                  Hello Sharp TV experts
                  Our Sharp LC-80LE642U displays one short one long flash error code which is a backlight error. I went into service mode and there were 8 lamp error counts recorded. I reset the count to 0 and did a reset. The last monitor error cause was 16 B00014639:12. 16 is the code for backlight error. I tried to power the tv up but went back into error mode.
                  > I checked voltages on the power supply board and they all check out .. including 3.28 volts at the error pin.
                  > There is power to the cpu and T-CONN and no faults found there. The cpu has a flashing...
                  01-24-2025, 11:51 PM
                • cheeky2
                  Sony RB2G Chassis KDL-55W815B MAIN BOARD 2 Blink Error issue resolved! Happy days :)
                  by cheeky2
                  For anyone interested just repaired this Sony Main board TV that had a 2 blink error code, the chassis is a RB2G which is common to quite a few different Sony models. The Ceramic 10uF 25V X7R 1206 capacitor C9114 was shorted which took the smd 2A 0603 fuse out F9101. This was powering the Buck converter TPS54332 which caused no 5V output from it.
                  See the attached picture of the locations of both components. I also attach the best service manual I found for this board for anyone else in a similar position of trying to repair this main board. It's not specific to the TV model however it gives...
                  01-08-2024, 05:56 AM
                • Curtissimo
                  HP EliteBook 850 G8 - Error code / Caps Lock permanently on and blinks twice every 6 seconds
                  by Curtissimo
                  Hi everyone.
                  I have a HP Elitebook 850 G8.
                  Serial: 5CG2324XM0
                  ProdID 6L8D5EC#ABA
                  It has a Winbond W25Q256JVEN Chip.
                  I need to remove BIOS Password.
                  I made a dump with an CHA341A programmer and NeoProgrammer 2.2.0.10.
                  Attached my dump.
                  I also used the HP Unlocker tool to create an unlocked file (I followed the guidelines)
                  I also downloaded latest HP BIOS Update (SP158137) which includes 3 .bin files. I found the Number T76 in my original dump, so I used: T76_01210000.bin
                  What I did:...
                  08-26-2025, 04:42 AM
