After bios repair of 6th gen Hp desktop and all in one pc, "SYSTEM IS BOOTING IN MANUFACTURING PROGRAM MODE" message appears on screen in startup. I tried adding build id, serial number, product number, product name and feature byte in bios setup but it didn't work. Is there an easy way to solve this problem because I am not so good at using special software for bios editing. Any kind of help would be greatly appreciated. Thanks.
How to remove this message after bios repair of 6th gen hp pc?
Re: How to remove this message after bios repair of 6th gen hp pc?
can you attach your config.txt file -
you need to use (BCU) biosconfigutilty tool to set the system info.
its widely available to download here. once you applied the MDM popup will go away.Last edited by reddemonic; 03-20-2022, 06:45 AM.Comment
yes.
https://www.youtube.com/watch?v=r2ubpyeUOB4
https://www.youtube.com/watch?v=9T57ktw8n3YComment
After bios repair of 6th gen Hp desktop and all in one pc, "SYSTEM IS BOOTING IN MANUFACTURING PROGRAM MODE" message appears on screen in startup. I tried adding build id, serial number, product number, product name and feature byte in bios setup but it didn't work. Is there an easy way to solve this problem because I am not so good at using special software for bios editing. Any kind of help would be greatly appreciated. Thanks.Comment
Attached FilesComment
I tried several times to recover the corrupted bios of these 6th gen hp desktop and all in one pcs by creating a recovery usb drive on another pc but it didn't work. It worked very well for recovering 8th gen hp desktop pc bios. Is there any way to recover bios of these 6th gen pcs through recovery usb?Comment
Repaired file.Attached FilesComment
Try this.Attached FilesComment
by tlindiSublect line continuation: ... Jaguar IDS PC aka Panasonic
Ack
Ack
Channel: BIOS Requests ONLY!
by Vesko356First of all thanks to all of our members who have posted previously all methods posted here.
Operating system and OS version.If...-
by jbonavitaHi, my laptop wont boot at all
Some issues
Things I tried
1- Update / clear ME: Took the non working bios, made a backup, and did this: https://www.badcaps.net/forum/troubl...theory/trouble...-
by iulik17dHello everyone!
The Asrock A380 low profile card (ID 8086 56A5 - 1849 6006) have an power limit of 45W. Intel removed the possibility to increase power using the software utility, anyway the card is in an proxmox machine that doesn't run windows.
The same hardware is in another form by the name Asrock A380 Challenger that have the same VRMs and the power limit is at 60W. I searched online and found on another website an .bin bios file from the Challenger variant, that I flashed using an CH341a. Flashng worked well, I put the card in PC and booted. GPUz shows that new device ID is 8086...-
01-10-2025, 02:33 PM -
by WahazHello,
I found 3 bios chips on the board, which I read with a bios programmer: two XMC model bios chips and a Winbond model bios chip. Each XMC model bios chip has two partitions named XM25QH128A [3.3V] and XT25F128A [3.3V]. And the Winbond model bios chip has three partitions named W25Q80BL 3.3V, W25Q80xV 3.3V and W25Q80DV 3.3V....-
- Loading...
