HP Prodesk 600 G3 SFF Bios Request
  • lrservicios
    • May 2016
    • 137
    • españa
    Good Morning Guys Im looking for a working BIOS for a
    HP Prodesk 600 g3 SFF Small Factor Form
    ARA REV: A 901198-001 PFYVB0A0Z575PY
    911988-001 911988-601
    Here i attach ORIGINAL dump, i think its corrupted
    • 21874
    Re: HP Prodesk 600 G3 SFF Bios Request
    The ME firmware was corrupted. Try this fixed one
    • lrservicios
      • May 2016
      • 137
      • españa
      Thank you very much Sir, it worked flawesly ... PERFECT !!!
        • 21874
        Super
        • santi2019
          • Jun 2019
          • 9
          • españa
          Good Morning Guys Im looking for a working BIOS for a HP Prodesk 600 g3 SFF Small Factor Form
          Thanks!!
          • peste
            • Dec 2016
            • 13581
            • ROMANIA
            Thanks!!
            try post#2...
            • santi2019
              • Jun 2019
              • 9
              • españa
              The bios in post2# works correctly, I have programmed it on a functional pc and it works correctly.
              The problem I have is not bios.
              My problem is that I have no voltage on pin 45 of the super IO (pw_btn_out), I have 0.5 v and it should have 3.2 v.
              I have changed super IO, but still with the same problem.
              Any idea to try to solve the problem?
              Thanks!!
              • sebkarimpour@gmail.com
                Valiasr
                • Aug 2019
                • 25
                • Iran
                Thank u sir
                  Valiasr
                  • Aug 2019
                  • 25
                  • Iran
                  Originally posted by sebkarimpour@gmail.com
                  Thank u sir
                  it must be short circuit between power botton and super io and hav to serach for this
                  • victorgt0794
                    • Dec 2022
                    • México
                    Hello, I need your help. I have an HP Prodesk 600 G3 SFF that does not detect the keyboard and mouse in two ports, but does detect a data USB. Of the 6 USB ports on the back, only 2 fail.
                    • peste
                      • Dec 2016
                      • 13581
                      • ROMANIA
                      post S/N, motherboard model, post the contents of the bios chip even if it is corrupted..etc.
                      • bilal1992
                        • May 2017
                        • 26
                        • algeria
                        working . god bless you
                        • jef1995
                          • May 2025
                          • 4
                          • usa
                          The network motherboard is not work after updating the BIOS. The network port light is fixed to orange. I programmed two more files, but there was no change.
                            • 21874
                            Thread merged. Read the rules, post the PC serial number ,and your original bios backup.
                            • jef1995
                              • May 2025
                              • 4
                              • usa
                              sn :JPH805YWWF
                              pn :Y3F34AV
                              backup is missed
                                • 21874
                                sn :JPH805YWWF
                                pn :Y3F34AV
                                backup is missed
                                Post 2 -> https://www.badcaps.net/forum/troubl...ss#post1465160 try the MAC address tools
                                  • 21874
                                  sn :JPH805YWWF
                                  pn :Y3F34AV
                                  backup is missed
                                  Post the current bios backup and the MAC address
                                  • jef1995
                                    • May 2025
                                    • 4
                                    • usa
                                    MAC: 18:60:24:F2:76:B9
                                    • jbonavita
                                      by jbonavita
                                      Some issues
                                      Things I tried
                                      04-29-2025, 09:38 PM
                                    • FalconPunch
                                      Surface Pro X 1876 Bios corrupted
                                      by FalconPunch
                                      Hello everyone, I happen to have a Microsoft Surface Pro X 1876 in my hands. It was brought to me by a friends which happen to have taken off the bios chip to test another motherboard. Upon putting back the bios chip on the original motherboard, The PC is stucked on Windows logo and won t boot to bios or anything. I suspect that the changes of bios chip somehow corrupted the firmware inside. Is the hypothesis correct?
                                      Also i extracted the bios inside the chip which was on Winbond 25R128JWPQ you can find the file attached if you can fix it (if possible, I would like some insight on...
                                      08-09-2025, 03:56 AM
                                    • zenius
                                      by zenius
                                      12-08-2024, 06:13 AM
                                    • Wahaz
                                      by Wahaz
                                      10-30-2023, 08:42 PM
                                    • zlr8r
                                      Hp Zbook Firefly 14 G10 - corrupted Bios's ? - please check
                                      by zlr8r
                                      Greetings
                                      I am hoping someone could have a check of my Hp Zbook Firefly 14 G10 , 2 x 32MB Bios files... (powers on / black screen).
                                      Serial Number: 5CG3202C16
                                      Product #/SKU: 739P0AV
                                      CT Number: PRTUE00WBI30YX
                                      Description: HP ZBook Firefly 14 inch G10
                                      BuildID: 23WWWGAZ602#SABU#DABU
                                      Feature Byte: 476J6S6b7B7M7Q7U7W7m7saBaEapaqauawbUbhcAfPgSguhKj4jhk8mEn7nVngpDpVpWpnpqprqMqkqz.G3
                                      MAC address not found.
                                      • I extracted both 32mb bios files (Main + EC). But when i run the main 32mb bios through MFIT.exe , it produces this error; ie:,
                                      Today, 01:56 PM
