HP 800 G1 TWR missing mac address
  • zenek_19
    • Mar 2017
    • 73
    • poland
    Could someone add mac address becouse there are only FFFFFFFFFFFFF
    it can be 8CDCD43377E8
    • 21058
    Re: HP 800 G1 TWR missing mac address
    Try these intel MAC address tools.If it doesn`t work try the intel mac address tools from ASRock - https://www.asrock.com/support/download/mactool.asp
    • zenek_19
      • Mar 2017
      • 73
      • poland
      OK thanks MAC changer from ASROCK working.
      • odif
        • Aug 2021
        • morocco
        hi zenek
        hw you did it please ??
        • rtstorm
          • Feb 2012
          • 971
          • Croatia
          hi to all, i would also need a little help in changing MAC, can you please give me a little walk ?
          ...the quieter you become the more you are able to hear...
          • jef1995
            • May 2025
            • usa
            The files that are programmed have a MAC address but the network still doesn't work.
            • peste
              • 12887
              • ROMANIA
              update the drivers..
              • kotel studios
                Asrock 970 PRO3 - missing 1.1V on NorthBridge
                by kotel studios
                Recently I got this Asrock 970 PRO3 board from scrap. It had a few missing caps under the NB which I've replaced. Sadly, one of them went short (NC597 from boardview file). I did replace it and there doesn't seem to be any shorts left, but the board is not executing POST nor beep codes. I once got it to POST after I was slightly bending it, but that was only once. I tried to redo the same steps but to no avail. All caps on the backside of NB have 22-ish ohms.
                I have traced the problem to an dead Northbridge VRM. There's no voltage on Phase (pin 8), FB (pin 6), UGATE...
                08-02-2025, 02:34 AM
              • ugamazing
                820-02020 PPBUS_AON missing
                by ugamazing
                Board had no history of liquid; unsure of drop history, but no signs of damage of any kind worth noting.
                Charger sitting at 5v/0a. PPBUS is at 1.9v-0.9v steady cycle (peaks, drains, loops). Confirmed CHGR_EN_MVR is missing, but DCIN was reaching ISL just fine, so replaced ISL--no change at all. Confirmed pp3v8_aon is also missing--and being unsure *exactly* which signal appears first (or if they are simultaneous), I inspected PMU/U8100 area and found no shorts, but also found PP3V8_AON_MPMU_ISNS_VIN missing (not shorted). Replaced U8100 just in case (have had them fail in weird ways),...
                02-05-2025, 04:21 PM
              • jpreza
                Apple NVIDIA AGP GeForce 6800 GT Dual Link DVI+DVI outputs 603-6338 missing caps!
                by jpreza
                I recently acquired this card from a seller who was selling a PowerMac G5 for parts. He mentioned that the video card was probably broken too.
                Upon closer inspection, I can tell the reason why it won't work: it's missing a bunch of CAPS! (it's also missing an inductor - 1.0uH).
                It's a nice card as it's one of the few AGP cards that will support 2560 x 1600 resolution on a PowerMac G5 using a 30" Cinema Display.
                Looking at the card, it appears to be missing the following:
                1x 1.0uH inductor - orange square
                2x...
                11-01-2024, 10:54 PM
              • mouuse25
                Asrock Z390 Taichi, missing chip
                by mouuse25
                Hello, I need help figuring out what chip came unattached from my motherboard (Asrock Z390 Taichi). I found a picture online of the chip. However I cannot find a boardview or a high resolution picture to identify what it was.
                My assumption is that it is a buffer logic 74LVC1G125GW. judging by a Z270 Taichi boardview I found but not really a fan of smoke testing parts.
                Any and all help is appreciated - Thanks
                03-24-2022, 08:17 PM
              • gurj1979
                Asus Zenbook UX431DA / UM431D - Ryzen - missing PWM Fan Signal.
                by gurj1979
                Hey guys.
                Need help with this one.
                Fan not spinning due to missing PWN Fan signal.
                Also 5 seconds from powering up it freezes, unless in BIOS.
                But as soon as Windows starts to load, it will freeze.
                CPU is COLD / Room temp when it freezes.
                I've replaced the CPU, same problem.
                Replaced SIO/KBC IT8987e and reprogrammed - same problem.
                Replaced fan - same problem.
                Replaced flex cable from board to daughterboard (which has fan connector on it) - same problem.
                Checked the Thermal sensors around CPU and Board to the SIO/KBC and...
                08-19-2024, 05:22 PM
