Bios for Z420
    Bios for Z420
    Hi I have problem with Z420 after HP Logo Display everything freeze, i try some bios files in Forum but not working
    Re: Bios for Z420
    here you are
      hi my z420 has freeze at hp logo, re flashed by that file you uploaded and now its ok but i have Invalid electronic serial nomber,i think i should have the serial number from old bios dump and i have the old one but i dont khow how to fine and inject to the new bios,i will upload my old dump in down of this post thanks full if you can help me
      serial number : SGH238TZG8
      Thanx
        bump
          bump
          Serial number is not real, check again.
          Click image for larger version  Name:	2024-07-28 19_03_01-Official HP® Desktop Drivers and Software Download _ HP® Support.png Views:	0 Size:	71.2 KB ID:	3317798
          Become a Badcaps supporter
          Thanks to all supporters.
            hi my friend,thanx for your attention,that is right but this is write on the case and even inside my old bios dump
              Search by product number instead. LJ449AV
                Thank you , SMDFlea !
                HP Z420 Base Model Workstation
                  in new bios i put serial number manually, thanxxx for your big help
                    Hi All, I recently picked up two HP z420 PCs that have a boot block date from 2011 and are still on BIOS rev 1.02. I've been doing some reading and I need to first update to 1.07, then 1.23 before I can update to the most recent (3.96 I think it is), but I can't for the life of me find a download for the older versions. The official HP links are broken and this is the first place I found with any downloads but it seemed like these may be custom edited BIOS files so I wanted to query SMDFlea and see if they could send me in the right direction. Thanks in advance for any help.
                      Post the PC serial and product numbers
                        First PC:
                        - Product Number: LJ449AV
                        - Serial Number: 2UA2310457
                        Second PC:
                        - Serial Number: 2UA2490F6R
                        🙏 Thank you 🙏
                          First PC:
                          Second PC:
                          🙏 Thank you 🙏
                          You can step up to version 1.23 first then to the latest.Read the comments by DGroves --> https://h30434.www3.hp.com/t5/Busine...s/td-p/8078192
                          The link for the 1.23 is ftp.hp.com/pub/softpaq/sp64501-65000/sp64701.exe .You can extract the softpaq using 7-zip or winRAR
                            I appreciate the response. I already found that post prior to responding to this one and could not get the links to work in Edge or using FileZilla on 2 different windows PCs, one an HP laptop.
                            Do I need to use the PC I am attempting to update to access them?
                            Thanks Again!
                              Thanks Again!
                              Here`s sp64701.exe
                                Here`s sp64701.exe
                                THANK YOU THANK YOU THANK YOU!!!!!!!! I just successfully updated the BIOS to 1.23 and then 3.96!!!!!!!! Next will be to update the second of the machines. Thank you so much. You're a project saver!
                                  SMDFlea commented
                                  Editing a comment
                                  You`re welcome, happy to help :-)
