Bios for Z420
  • digitalpc
    • Jun 2016
    • 305
    • .DLL
    Bios for Z420
    Hi I have problem with Z420 after HP Logo Display everything freeze, i try some bios files in Forum but not working
  • xuandan
    • Sep 2017
    • 18
    • viet nam
    Re: Bios for Z420
    here you are
    • alijoon30
      • Sep 2017
      • 10
      • iran
      hi my z420 has freeze at hp logo, re flashed by that file you uploaded and now its ok but i have Invalid electronic serial nomber,i think i should have the serial number from old bios dump and i have the old one but i dont khow how to fine and inject to the new bios,i will upload my old dump in down of this post thanks full if you can help me
    • alijoon30
      • Sep 2017
      • 10
      • iran
      serial number : SGH238TZG8
      Thanx
      • alijoon30
        • Sep 2017
        • 10
        • iran
        bump
        • hoaca388
          Badcaps
          • Jan 2022
          • 12139
          bump
          Serial number is not real, check again.
          Click image for larger version  Name:	2024-07-28 19_03_01-Official HP® Desktop Drivers and Software Download _ HP® Support.png Views:	0 Size:	71.2 KB ID:	3317798
          • alijoon30
            • Sep 2017
            • 10
            • iran
            hi my friend,thanx for your attention,that is right but this is write on the case and even inside my old bios dump
              • 21473
              Search by product number instead. LJ449AV
              • hoaca388
                Badcaps
                • Jan 2022
                • 12139
                Thank you , SMDFlea !
                HP Z420 Base Model Workstation
                • alijoon30
                  • Sep 2017
                  • 10
                  • iran
                  in new bios i put serial number manually, thanxxx for your big help
                  • James McKissick
                    • Dec 2024
                    • 5
                    • US
                    Hi All, I recently picked up two HP z420 PCs that have a boot block date from 2011 and are still on BIOS rev 1.02. I've been doing some reading and I need to first update to 1.07, then 1.23 before I can update to the most recent (3.96 I think it is), but I can't for the life of me find a download for the older versions. The official HP links are broken and this is the first place I found with any downloads but it seemed like these may be custom edited BIOS files so I wanted to query SMDFlea and see if they could send me in the right direction. Thanks in advance for any help.
                      • 21473
                      Post the PC serial and product numbers
                      • James McKissick
                        • Dec 2024
                        • 5
                        • US
                        First PC:
                        - Product Number: LJ449AV
                        - Serial Number: 2UA2310457
                        Second PC:
                        - Serial Number: 2UA2490F6R
                        🙏 Thank you 🙏
                          • 21473
                          First PC:
                          Second PC:
                          🙏 Thank you 🙏
                          You can step up to version 1.23 first then to the latest.Read the comments by DGroves --> https://h30434.www3.hp.com/t5/Busine...s/td-p/8078192
                          The link for the 1.23 is ftp.hp.com/pub/softpaq/sp64501-65000/sp64701.exe .You can extract the softpaq using 7-zip or winRAR
                          • James McKissick
                            • Dec 2024
                            • 5
                            • US
                            I appreciate the response. I already found that post prior to responding to this one and could not get the links to work in Edge or using FileZilla on 2 different windows PCs, one an HP laptop.
                            Do I need to use the PC I am attempting to update to access them?
                            Thanks Again!
                              • 21473
                              Thanks Again!
                              Here`s sp64701.exe
                              • James McKissick
                                • Dec 2024
                                • 5
                                • US
                                Here`s sp64701.exe
                                THANK YOU THANK YOU THANK YOU!!!!!!!! I just successfully updated the BIOS to 1.23 and then 3.96!!!!!!!! Next will be to update the second of the machines. Thank you so much. You're a project saver!
                                  SMDFlea commented
                                  Editing a comment
                                  You`re welcome, happy to help :-)
                              • xazer
                                • Sep 2025
                                • 3
                                Hi everyone! I assembled two Z420 machines. One started without any issues, but I ran into problems with the second one. The motherboard (618263-002) started up for the first time with a v1 processor. I updated the BIOS, replaced the CPU with a v2, and it stopped booting. Nothing helped, including returning to the first v1 CPU the fans just throttling and the screen remained black. I tried emergency recovery with a flash drive, but it didn’t work 8 flashes and 8 beeps appeared at startup.
                                I created a dump, inserted the padding section into the BIOS 3.96 from the website, but that also didn’t help still 8 flashes and 8 beeps.
                                  • 21473
                                  • xazer
                                    • Sep 2025
                                    • 3
                                    Thank you for your prompt response! Since all the components were purchased separately I don’t have a sticker with the serial or product number.
                                    But based on the BIOS dump the serial number is 2UA4271JTZ
                                    The product number is most likely LJ449AV
                                    The motherboard part number is 618263-002
                                    • throwaway327
                                      by throwaway327
                                      Model No: RC72LA
                                      Serial No: SBNVKD001014459
                                      06-18-2025, 05:52 PM
                                    • q2v5
                                      Lenovo T480s, what's up with this Bios, modded boot logo, reflashed now bricked
                                      by q2v5
                                      Lenovo T480s
                                      Model 20L8-S3TE00
                                      Board ET481-U10
                                      Chip MX25L12873F
                                      Hi, I have a few of these & they came with a custom bios boot logo, no passwords etc.
                                      2 x were brand new unused but with custom boot logo, 1 I installed Windows/ran updates then it bricked itself. 1 wouldn't get past the custom bios boot logo.
                                      The third I loaded windows, took a backup of the bios chip, then tried to flash several different clean bios's via programmer which all caused it to not boot. I tried to reflash the original bios both using clip & desoldering but...
                                      08-15-2024, 10:40 PM
                                    • Vesko356
                                      by Vesko356
                                      08-11-2023, 03:27 AM
                                    • jbonavita
                                      by jbonavita
                                      Some issues
                                      Things I tried
                                      04-29-2025, 09:38 PM
                                    • zenius
                                      by zenius
                                      12-08-2024, 06:13 AM
