i need bios asus aio et2231i rev:1.3
  • tugrul63
    • May 2015
    • 94
    • türkiye
    hi
    et2231i rev:1.3 main board
    main+ec bios dump.
  • tugrul63
    • May 2015
    • 94
    • türkiye
    Re: i need bios asus aio et2231i rev:1.3
    test ok working
    • ebrahimtaheri
      • Jan 2020
      • us
      hi i need et2020a rev 1.3 bios
        • 20952
        Its different model to the one in the thread topic "et2231i" . Start your own thread .
        • razor_amd
          by razor_amd
          12-15-2020, 07:07 PM
        • DynaxSC
          by DynaxSC
          06-14-2024, 03:49 PM
        • jbonavita
          by jbonavita
          Some issues
          Things I tried
          04-29-2025, 09:38 PM
        • Habble7
          by Habble7
          Suspected Cause:
          Troubleshooting Attempts:
          05-22-2025, 07:28 AM
        • Anchar777
          ASUS P1412CE need BIOS DUMP
          by Anchar777
          Sorry for creating a second post, I didn't understand how to fix the error in the message. I need help, laptop ASUS P1412CE (P1411CEA-EK0395X) SN: N4NXCV033901146. There was a failure during BIOS flashing, and the laptop stopped turning on. The original, non-working BIOS is attached. Unfortunately, I was unable to correctly generate the BIOS from what is presented on the Asus website. Help me make a dump. Thank you....
          06-26-2025, 03:39 AM
