i need bios asus aio et2231i rev:1.3
  • tugrul63
    • May 2015
    • 94
    • türkiye
    hi
    et2231i rev:1.3 main board
    main+ec bios dump.
  • tugrul63
    • May 2015
    • 94
    • türkiye
    Re: i need bios asus aio et2231i rev:1.3
    test ok working
    • ebrahimtaheri
      • Jan 2020
      • 3
      • us
      hi i need et2020a rev 1.3 bios
        • 21853
        Its different model to the one in the thread topic "et2231i" . Start your own thread .
        • mkdj
          by mkdj
          Dear all,
          10-19-2025, 04:41 AM
        • razor_amd
          by razor_amd
          12-15-2020, 07:07 PM
        • DynaxSC
          by DynaxSC
          06-14-2024, 03:49 PM
        • Ahari
          by Ahari
          I...
          08-13-2025, 06:12 AM
        • jbonavita
          by jbonavita
          Some issues
          Things I tried
          04-29-2025, 09:38 PM
