Asus P6T dump bios
  • akis24
    • Dec 2018
    • 11
    • italia
    Asus P6T dump bios
    hi I have a problem with an asus pt6 motherboard after trying to update the bios an error message appeared in writing the next restart the card remains stationary without any post phase I proceeded to unplug the bios and try to read the content with a ezp2013 programmer but it was basically empty I tried to write the latest version of the bios 1402 available on the asus site but everything as before no start at this point I was suggested to try to flash the bios with a complete dump someone by chance has full bios dump available the chip mounted on the motherboard is a MX25l1605D thanks in advance anyway and sorry for the bad english
    • 21841
    Re: Asus P6T dump bios
    Are you sure about version 1402 ,its not on the support page for the P6T or P6T Deluxe .What model number is your motherboard exactly ?
    • akis24
      • Dec 2018
      • 11
      • italia
      Sorry Version 1408 2010/11 966.48 KBytes
        • 21841
        All the bios versions are available at asus support - https://www.asus.com/Motherboards/P6T/HelpDesk_BIOS/
        • mkdj
          by mkdj
          Dear all,
          10-19-2025, 04:41 AM
        • razor_amd
          by razor_amd
          12-15-2020, 07:07 PM
        • DynaxSC
          by DynaxSC
          06-14-2024, 03:49 PM
        • Ahari
          by Ahari
          I...
          08-13-2025, 06:12 AM
        • jbonavita
          by jbonavita
          Some issues
          Things I tried
          04-29-2025, 09:38 PM
