hi I have a problem with an asus pt6 motherboard after trying to update the bios an error message appeared in writing the next restart the card remains stationary without any post phase I proceeded to unplug the bios and try to read the content with a ezp2013 programmer but it was basically empty I tried to write the latest version of the bios 1402 available on the asus site but everything as before no start at this point I was suggested to try to flash the bios with a complete dump someone by chance has full bios dump available the chip mounted on the motherboard is a MX25l1605D thanks in advance anyway and sorry for the bad english
Asus P6T dump bios
Re: Asus P6T dump bios
Are you sure about version 1402 ,its not on the support page for the P6T or P6T Deluxe .What model number is your motherboard exactly ? -
All the bios versions are available at asus support - https://www.asus.com/Motherboards/P6T/HelpDesk_BIOS/Comment
by mkdjDear all,
I would appreciate if someone could take time to explain the issue, so that I can learn. But I would...-
Channel: BIOS Requests ONLY!
by razor_amdWith ASUS, not everything is quite so simple. I will show you my way. It may be longer or harder but it is the right way to do it in my humble opinion.
This is the picture of 3 similar ASUS motherboards, all of them being X555LD...-
by piratiHello everyone,
I decided to try flashing a new BIOS, but since I didn’t want to desolder...-
Today, 04:20 PM -
by DynaxSCHi,
Usually on ASUS boards it worked...-
by AhariHi all,
I...-
- Loading...
