packard-bell-onetwo-l5861 model number
Need h67h2-ad ver 1.0 bios dump
Re: Need h67h2-ad ver 1.0 bios dump
Try post n4 : https://www.badcaps.net/forum/showthread.php?t=74945 -
Try post n4 : https://www.badcaps.net/forum/showthread.php?t=74945Comment
Its a bios update. Merge it with your bios backup using a hex editor, clean the ME firmware, copy the DMI info from the bios backup and the bios might be ok after all that work.Comment
Post your bios backup.....Comment
old biosAttached FilesComment
try..Attached FilesDue to a lack of donations, server free space at a critical level, and possible closure of Bios Requests all donations are welcome, click:
Every donation made will go towards server fees and maintenance costs.Comment
gUYS, HUGE thanks, this damp helped to revive Acer Aspire Z5761 All in one desktop with this main board inside. I realized that BIOS published on the Acer web-site does not work, I programmed it and fan just rotated once and then stop. So Thanks again kind Sirs!Comment
Hello guys!
I also have an ACER ASPIRE Z5761 with the same MB, and I,ve tryed upgrading the cpu from a 2nd gen I3 2100 to a 3rd gen i5 3570, and does not boot… is this version of bios good for 3rd gen cpus??? Should i do it? peste bro daca esti amabil te rog mult ajuta-ma cu un sfat! 🫡Due to a lack of donations, server free space at a critical level, and possible closure of Bios Requests all donations are welcome, click:
In general ME 8, updated VGA ROM and Ivy Bridge microcodes are required for a BIOS to support Ivy Bridge CPUs. H67H2-AD does not seem to have a BIOS with that. H61H2-AD does so it might be possible to make a modded BIOS.OpenBoardView — https://github.com/OpenBoardView/OpenBoardViewComment
Due to the fact that I am not comfortable doing it the old fashion way by booting from an usb stick and writing the commands, I have that only once in my life in like 2006 ...
Best regards, check your PM plzComment
I have already put back the I3, however I want to know if the bios made by you does have an updated CPU list, and it's worth the struggle of bios update!
by Habble7The Samsung S49CG934SU monitor does not power on - no LED indicator activity and no response to power button. However, when 21V power is connected, it immediately draws 0.8A of current with no display output. The motherboard processor gets warm, and there is continuous reading activity from the W25Q128BV BIOS chip.
Suspected Cause:
Troubleshooting Attempts:
by DynaxSCHi,
I need a BIOS dump for MSI Z590 PRO WIFI from a real physical board, along with MAC address and serial no.
It must be a dump from a physical board, as it contains personalized data eg. MAC Address, UUID, Serial no.
I have a board which has lost the BIOS contents, I have the MAC and serial to this board, and need to insert it into the another BIOS image. To do it, I need to have a real image from a real board, as the images from the MSI site are without this data. The only way to find where MAC/UUID/Serial is located in the BIOS is to have a bios...-
11-06-2022, 05:22 PM -
I'm trying to recover a Fujitsu Lifebook E5513 (most likely 2023 model) that was bricked during a BIOS update. The update was interrupted (probably due to power loss), and now the laptop is stuck in a boot loop showing "PBB rollback" / "SBB rollback" messages.
BIOS access (F2) and Boot Menu (F12) are no longer possible – the system instantly reboots after the rollback messages.
I extracted the official BIOS update package from Fujitsu (contains FJNB2FD.CAP, ~18.7 MB) and tried tools like UEFIExtract, but it seems to only contain...-
Channel: BIOS Requests ONLY!
by Vesko356First of all thanks to all of our members who have posted previously all methods posted here.
Operating system and OS version.If...-
by hyperwoodHi everyone,
I’m looking for a 2 MB BIOS dump for a Lenovo IdeaPad 5 16ARH7H / Legion 5 with mainboard NM-E471 Rev. 2.0.
The BIOS chip is a Winbond W25Q16FW (1.8V, 2MB) and it's completely unresponsive / bricked. I tried recovery via USB but no success. Now I want to reflash it externally using a CH341A programmer.
I already found 32MB dumps (e.g. from Vinafix and Badcaps), but they are too large for the chip – and the last 2MB in those files are just FF FF FF....
✅ What I need:- A working 2MB BIOS dump
- Matching NM-E471 Rev. 2.0, e.g. JY575
- Loading...
