need dump acer h61h2-ad v: 1.0
  • salim deia
    • May 2017
    • 18
    • algeria
    thnx.
    • 21471
    Re: need dump acer h61h2-ad v: 1.0
    Post your bios backup .Do you want the win 7 or 8 bios .
    • salim deia
      • May 2017
      • 18
      • algeria
      http://ww******************d.bin/file
      i have changed the battery 3v . But does not save settings in bios setup.
      tnx a lot.
        • 21471
        Try this one.
        • salim deia
          • May 2017
          • 18
          • algeria
          SMDflea
          its same erreur.
            • 21471
            The bios is straight from acer, so should not be a bios problem.Check the traces running from the bios battery,check caps ,diode - maybe bat54c .
            • raedinformatique
              • Feb 2018
              • 25
              • algeria
              Originally posted by SMDFlea
              Try this one.
              Thank you it is OK in Acer veriton x2611G with motherboard H61 H2-AD.
              Thank you again.
              • TIXOU14
                • Aug 2020
                • 15
                • TIARET
                Originally posted by smdflea
                try this one.
                your dump is 8 mb in my bord is chip of 4mb
                • TIXOU14
                  • Aug 2020
                  • 15
                  • TIARET
                  Need bios of 4mb
                  • kosmonaft
                    • Mar 2016
                    • 7
                    • Россия
                    So, any correct dump at 4mb?
                    • rex98
                      • Feb 2023
                      • 1287
                      • Mandaue CEBU, Philippines
                      no display. please fix 4MB BIOS DUMP
                      • peste
                        • Dec 2016
                        • 13199
                        • ROMANIA
                        try...
                        • nassimhamdi
                          • Feb 2016
                          • 150
                          • algeria
                          hi i nedd h61h2-ad v: 2.0
                        • James194zt
                          Acer Nitro 50-640E Corrupted BIOS Dump
                          by James194zt
                          My daughter has accidentally managed to kill her Acer gaming desktop it has a blank screen after updating and when you press the power button the fans spin, light comes on and it makes 1 long and 1 short beep and no attempt to boot.
                          All basic troubleshooting has been done we replaced CPU, GPU and RAM from a working machine and no joy, I also noticed a post on here with the same issue and it was the BIOS. I am pretty sure also because it was doing a BIOS update that stopped it working, she knocked the keyboard out by accident during the update and the screen just went...
                          04-28-2025, 03:29 PM
                        • Ahari
                          by Ahari
                          I...
                          08-13-2025, 06:12 AM
                        • Habble7
                          I need a BIOS dump for the Samsung S49CG934SU monitor
                          by Habble7
                          The Samsung S49CG934SU monitor does not power on - no LED indicator activity and no response to power button. However, when 21V power is connected, it immediately draws 0.8A of current with no display output. The motherboard processor gets warm, and there is continuous reading activity from the W25Q128BV BIOS chip.
                          Suspected Cause:
                          I suspect the BIOS may have been corrupted during a power interruption while updating the firmware. The official website provides firmware updates, but they can only be installed via USB flash drive.
                          Troubleshooting Attempts:
                          05-22-2025, 07:28 AM
                        • x14nl34l
                          Acer TravelMate p614 (tmp614-51-g2-5442) bios dump
                          by x14nl34l
                          Hi, I need a bios dump for my Acer TMP614 (tmp614-51-g2-5442 bios dump). Thanks.
                          09-01-2025, 09:54 PM
                        • ZOrd_Z
                          Acer Predator P03-650 bios DUMP.
                          by ZOrd_Z
                          I need a bios dump to a Acer Predator P03-650 board.
                          Or to convert the .CAP file o a file to flash.
                          Thank's......
                          10-29-2024, 12:06 PM
