HI NEED BIOS FOR ThinkCentre E63z
BIOS ThinkCentre E63z
Every donation made will go towards server fees and maintenance costs. -
Every donation made will go towards server fees and maintenance costs.Comment
Re: BIOS ThinkCentre E63z
i found thisComment
This BIOS is for Intel Bay-Trail-D MB, there are also E63z with Intel Haswell MB - there is a code below RAM slots, mine has IHSW_U - an the BIOS is different.
I attached working BIOS for E63z with Intel Haswell MB.
I also wish to thank to user who rebuilt my damaged BIOS, I posted a BIOS request in wrong section (BIOS request for laptops) and admin deleted my post and didn't get his name, the BIOS was working but it hasn't serial and machine type -solved with lenovo maintenance diskette.----------------------------------------------------------------------------------------------------------------------------------------------------------------------
----------------------------------------------------------------------------------------------------------------------------------------------------------------------Comment
Thank you sooooo much!!!!This BIOS is for Intel Bay-Trail-D MB, there are also E63z with Intel Haswell MB - there is a code below RAM slots, mine has IHSW_U - an the BIOS is different.
This has fixed my PCComment
hi i need bios for ThinkCentre E63z 6050a26
This is oldComment
https://www.badcaps.net/donateComment
Need bios for this type
E63z All-in-One (ThinkCentre) - Type 10E0
s/n:P901MCQTComment
yes, this one
s/n:P901MCQTAttached FilesComment
Try.Attached Files----------------------------------------------------------------------------------------------------------------------------------------------------------------------
all donations are welcome,
>>>>> click on this link to donate via PayPal. <<<<<
by amgatI need a BIOS dump for ThinkCentre M910 Tiny.
The BIOS chip is : Winbond 25Q128JV
Board : IQ2X0IH ver 1.0
I was using a chip clip with my xgecu pro which led to a corrupt BIOS dump, and the BIOS chip was since re-flashed with the donor BIOS from this thread:
https://www.badcaps.net/forum/troubl...nkcentre-m910q
This donor BIOS is not working in my system (because...-
by NeddsmeHie.
I own a Lenovo ideapad v310-15IKB with an i5 7th generation with only Intel graphics configuration.
Now the heart of the problem is that I don't know when or how it happened but I suddenly started getting distortion in the graphics output on the LCD. This basically meant a black screen full of flickering multicolored short horizontal lines. This would happen 30-60 minutes after booting and using it normally.
I run Windows 10 20H build so I thought it was just a Windows update issue or graphics driver outdated issue.
I managed to run Windows troubleshooting and...-
Channel: BIOS Requests ONLY!
by WahazHello,
I found 3 bios chips on the board, which I read with a bios programmer: two XMC model bios chips and a Winbond model bios chip. Each XMC model bios chip has two partitions named XM25QH128A [3.3V] and XT25F128A [3.3V]. And the Winbond model bios chip has three partitions named W25Q80BL 3.3V, W25Q80xV 3.3V and W25Q80DV 3.3V....-
I'm not a super pro like some here, when it comes to firmware. I have a machine with the following specs:
ENVY X360
15-ew0013dx
SN: CND2261KS3
Prod: 698V0UA
Board: LA-M021P Rev 1A
Chip# Winbond 25R128JVSN
Basically, when I power it up, I get no video, and the fans run hard - nothing else. Seems like a BIOS issue to me, so I posted a request in the BIOS request section. I haven't heard anything back(and that's fine) So I tried downloading the BIOS from HP, then I extracted it and flashed it onto the chip. Unfortunately, all I get is the power...10-09-2024, 08:40 AM - Loading...
