BIOS for ThinkCentre M910 Tiny
  • amgat
    Tinkerer
    • Feb 2021
    • 7
    • Norway
    I need a BIOS dump for ThinkCentre M910 Tiny.
    The BIOS chip is : Winbond 25Q128JV
    Board : IQ2X0IH ver 1.0
    I was using a chip clip with my xgecu pro which led to a corrupt BIOS dump, and the BIOS chip was since re-flashed with the donor BIOS from this thread:
    https://www.badcaps.net/forum/troubl...nkcentre-m910q
    This donor BIOS is not working in my system (because I have board ver 1.0?). It could be an entire other reason of course.
    The symptom is that the board is power cycling every 2-3 seconds and there's no display.
    Any help is greatly appreciated
    • 22077
    Post your original bios backup and the PC serial number, and we`ll see if we can help.
    • amgat
      Tinkerer
      • Feb 2021
      • 7
      • Norway
      This is the corrupt dump. I tried running it through UEFITool and it came up as corrupt. Don't know if you're able to retrieve anything.
      Serial number is : PC0NAZVU
      Tnx for looking
      • hoaca388
        Badcaps
        • Jan 2022
        • 12392
        Tnx for looking
        Hope it works for your device.
        • amgat
          Tinkerer
          • Feb 2021
          • 7
          • Norway
          Thanx. Flashed the BIOS chip and re-seated the chip on the board. The PC is no longer power cycling - it's steady on.
          The fan is spinning, and the power LED is constant on. But there is no picture on the screen (tested both HDMI and DP).
          It seems that the CPU is heating up a little bit, but there is no power going through the coils around the CPU, so not sure what's going on there.
          Also, the USB ports are not powered (tried connecting a keyboard to see if the caps lock is lighting up which it does not).
          I've checked the CPU socket for bent pins. Originally there was one pin that looked lite it was touching another pin which I bent back into position. Don't know if that might have damaged the CPU, but I have placed an order for a new CPU for testing.
          Not sure what the symptoms for a dead CPU of this type might be
          Any other suggestions are highly welcome
          • amgat
            Tinkerer
            • Feb 2021
            • 7
            • Norway
            I left the computer on without connecting the cooling fan, and the CPU was heating up to a point where it did a thermal shutdown. That tells me that the CPU is actually working right?
            By the way hoaca388, did you generate a new UEFI bios using the latest BIOS version from Lenovo?
            • hoaca388
              Badcaps
              • Jan 2022
              • 12392
              Yes, but i can't clear Me , maybe this is the reason.
              • amgat
                Tinkerer
                • Feb 2021
                • 7
                • Norway
                Can you use the Me data from this BIOS dump? Or create a new BIOS based on this dump?
                This is the BIOS dump from the first post I mentioned. Although i'm not sure if this is the correct BIOS for my system, it might be worth a shot.
                • hoaca388
                  Badcaps
                  • Jan 2022
                  • 12392
                  Here is the file I got me_region for you .
                  • amgat
                    Tinkerer
                    • Feb 2021
                    • 7
                    • Norway
                    There is no file attached
                    • hoaca388
                      Badcaps
                      • Jan 2022
                      • 12392
                      It can't clear me.
                      • amgat
                        Tinkerer
                        • Feb 2021
                        • 7
                        • Norway
                        Oh. Hm. Thank you for trying anyway. Much appreciated.
                        • mmaewbsoft
                          • Apr 2018
                          • 66
                          • yemen
                          Lenovo thinkcenter m910z
                          MT-M
                          SN / PC0UAYSQ
                          MACHINE TYPE / 10NUS1VC00
                          PRODUCT ID / 10NU
                          MODEL NM / S1VC00
                          Hi there help me and fix these bios this time The pc runs but no display. cpu not hot Lenovo thinkcenter m910z​
                          • hoaca388
                            Badcaps
                            • Jan 2022
                            • 12392
                            MT-M
                            SN / PC0UAYSQ
                            PRODUCT ID / 10NU
                            MODEL NM / S1VC00
                            M910z All-in-One (ThinkCentre) - Type 10NU
                            • mmaewbsoft
                              • Apr 2018
                              • 66
                              • yemen
                              not working but there are 2 ic bois behind motherboard 25q800 2 ic
                              • mmaewbsoft
                                • Apr 2018
                                • 66
                                • yemen
                                M910Z MT-M 10NU-S1VC00
                                SN / PC0U9Q5C
                                MACHINE TYPE / 10NU
                                PRODUCT ID / 10NUS1VC00
                                MODEL NUM/ S1VCC0
                                CPU NOT HEATING PLEASE REPAIR MY BACKUP
                                • hoaca388
                                  Badcaps
                                  • Jan 2022
                                  • 12392
                                  SN / PC0U9Q5C
                                  MACHINE TYPE / 10NU
                                  MODEL NUM/ S1VCC0
                                    LENOVO ThinkCentre M920 + ThinkCentre Tiny-in-One (TIO) 24 Gen3 ThinkCentre M i5-8500T Specification for Upgrade or Repair
                                    This specification for the LENOVO ThinkCentre M920 + ThinkCentre Tiny-in-One (TIO) 24 Gen3 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ThinkCentre M920 + ThinkCentre Tiny-in-One (TIO) 24 Gen3 boardview and ThinkCentre M920 + ThinkCentre Tiny-in-One (TIO) 24 Gen3 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly...
                                    09-12-2024, 01:58 PM
                                    LENOVO ThinkCentre M720q + ThinkCentre Tiny-In-One 24 ThinkCentre M i5-9400T Specification for Upgrade or Repair
                                    This specification for the LENOVO ThinkCentre M720q + ThinkCentre Tiny-In-One 24 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ThinkCentre M720q + ThinkCentre Tiny-In-One 24 boardview and ThinkCentre M720q + ThinkCentre Tiny-In-One 24 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum....
                                  • hotcrossedbuns999
                                    M715q Desktop (ThinkCentre) - Type 10M3 - Request bios chip location and useable bios for use with CH341A Programmer.
                                    by hotcrossedbuns999
                                    My pc updated bios through Windows Update and I was greeted with BLACK SCREEN WITH CPU FAN MAX SPEED. I don't think there is even a screen signal, because it triggers my monitor for a couple seconds and then the monitor turns off. I tried the other outputs as well.
                                    1. I tried clearing bios, resetting bios, removed the CMOS battery, removed m.2 ssd, wifi, and ram. Still black screen with CPU fan blasting.
                                    2. I tried using the Lenovo BIOS CD and BIOS USB, but neither worked. At least I couldn't get anything to work.
                                    3. I could only locate two chips that look like bios chips. Could someone verify this
                                    01-03-2025, 12:32 PM
                                  • tapialeorock
                                    Thinkcentre M83 Tiny 10E9 BIOS Dump
                                    by tapialeorock
                                    Hi, i'm looking for a TC m83 tiny type 10E9 with IS8XT v1.1 board bios dump.
                                    I somehow messed up with my bios image and the lenovo boot logo was replaced with nec logo.
                                    Lenovo's driver lookup tool is unable to recognize my computer in windows also.
                                    Changing the serial number manually with amidedos tool hasn't fixed the driver lookup issue.
                                    I have tried with thinkcentre m93p and m73 bios dumps, but none of them restored the lenovo boot logo nor the driver lookup issue.
                                    I'll leave my current bios dump.
                                    Thanks....
                                    09-28-2025, 01:32 PM
                                    LENOVO ThinkCentre M72e Tiny ThinkCentre M G460 Specification for Upgrade or Repair
                                    This specification for the LENOVO ThinkCentre M72e Tiny can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ThinkCentre M72e Tiny boardview and ThinkCentre M72e Tiny schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                    09-12-2024, 03:36 PM
