If I flash this bios file, will it just work, or does it need the ME cleaning?
+ More Options
Posts
  • survivalbloke
    • Aug 2021
    • 309
    I'm not a super pro like some here, when it comes to firmware. I have a machine with the following specs:
    ENVY X360
    15-ew0013dx
    SN: CND2261KS3
    Prod: 698V0UA
    Board: LA-M021P Rev 1A
    Chip# Winbond 25R128JVSN​
    Basically, when I power it up, I get no video, and the fans run hard - nothing else. Seems like a BIOS issue to me, so I posted a request in the BIOS request section. I haven't heard anything back(and that's fine) So I tried downloading the BIOS from HP, then I extracted it and flashed it onto the chip. Unfortunately, all I get is the power light on, and nothing else happens. I was searching this forum and I found https://www.badcaps.net/forum/troubl...in1-15-ew007nb Posts #4 and #7. If I flash one of those, will that work, or will I just need my original BIOS cleaned?
  • maanee11
    Looking for BIOS flash file for HUAWEI MateBook X Pro 2019 (MACH-WX9)
    by maanee11
    Hello Everyone,
    I have HUAWEI MateBook X Pro 2019 (MACH-WX9) whose BIOS got corrupted i beleive. I have acquired Ch341A SPI flasher to program the BIOS externally. I see that to program the BIOS, i need BIOS bin/hex file which i could use to reflash it externally via the flasher tool.
    It seems like the support page of this model no longer exist: https://consumer.huawei.com/be/lapto...ro-2019/specs/
    In the website, you can only see specs etc.
    I have not tried to extract the BIOS dump yet as I want to see if there is any ray of sunshine...
    Yesterday, 04:08 AM
  • to5it0
    by to5it0
    10-24-2025, 01:35 AM
  • abhorsen
    Help Disabling Flash Protection Range Registers on Lenovo P360 Tiny BIOS
    by abhorsen
    Hey guys,
    Hope you all are doing well. I come here from Win-Raid because I am having issues disabling Flash Protection Range Registers so I can flash my BIOS from within Windows using Intel's IFW tool/using flashrom within Linux, however I cannot due to the above mentioned error.
    Here is my thread on Win-Raid detailing the whole process I went through: https://winraid.level1techs.com/t/re...h-gen/95478/27
    Essentially I managed to boot into Windows while shorting PINs 1+5 of my audio chip to disable the HAP bit...
    07-06-2023, 10:22 AM
  • Citymin
    by Citymin
    S/N : 5RNK9FFT70...
    08-05-2025, 05:12 AM
  • testaccgta
    Unable to verify IC or write/erase/flash BIOS file to XMC QH128AHIG SPI chip using NeoProgrammer/AsProgrammer
    by testaccgta
    Hi, everyone!
    I've recently acquired two brand new SPI chips to replace the one currently in my Acer A514-54G laptop MB (FH5AT LA-K092P). The reason why I'm replacing the current SPI chip is because I had some difficulties with a third-party IT assistant who pretty much lacked the soldering skills and ended up destroying the current SPI chip soldered to my MB from factory.
    I've decided to do this on my own because I spent the past month or so learning some soldering skills and BIOS modding through Badcaps and WinRaid forums, hence the attempt. I've also chosen to buy...
    09-01-2024, 08:24 PM
