Asus Aio V230IC all in one bios
  • Fabbrone
    • Jun 2015
    • 158
    • italy
    Good morning I am looking for bios dump for this pc
    Thank
  • peste
    • 12872
    • ROMANIA
    Re: Asus Aio V230IC all in one bios
    post the original bios here
    • Fabbrone
      • Jun 2015
      • 158
      • italy
      unfortunately I found that the problem is much more serious, a bga is damaged
      • mac8181
        • Jul 2020
        • italia
        Thank
        • hardware1
          • Sep 2021
          • 2936
          • N/A
          Thank
          Upload your Original Backup, write your device Serial Number and someone will try to help you.
          all donations are welcome,
          • labo555
            • May 2015
            • 14
            • Italia
            bios asus v230ic
            hi all i need a bios file for my pc asus v230ic with black screen
            the pc turns on but with a black screen
            I am attaching my bios file which I think is corrupt
            thanks achie will help me
            the chip is a winbond 25q128fvsq
            s.n. g7ptcj017296
            • labo555
              • May 2015
              • 14
              • Italia
              Re: bios asus v230ic
              maybe it depends on this chip mxic 25l512e mi-10g
              • labo555
                • May 2015
                • 14
                • Italia
                help me please
                • peste
                  • 12872
                  • ROMANIA
                  Originally posted by labo555
                  help me please
                  bios extracted from Asus site update..
                  • razor_amd
                    by razor_amd
                    12-15-2020, 07:07 PM
                  • DynaxSC
                    by DynaxSC
                    06-14-2024, 03:49 PM
                  • Ahari
                    by Ahari
                    I...
                    08-13-2025, 06:12 AM
                  • jbonavita
                    by jbonavita
                    Some issues
                    Things I tried
                    04-29-2025, 09:38 PM
                  • Habble7
                    by Habble7
                    Suspected Cause:
                    Troubleshooting Attempts:
                    05-22-2025, 07:28 AM
