Asus Aio V230IC all in one bios
  • Fabbrone
    • Jun 2015
    • 158
    • italy
    Good morning I am looking for bios dump for this pc
    Thank
  • peste
    • Dec 2016
    • 12887
    • ROMANIA
    Re: Asus Aio V230IC all in one bios
    post the original bios here
    • Fabbrone
      • Jun 2015
      • 158
      • italy
      unfortunately I found that the problem is much more serious, a bga is damaged
      • mac8181
        • Jul 2020
        • italia
        Thank
        • hardware1
          • Sep 2021
          • 2939
          • N/A
          Thank
          Upload your Original Backup, write your device Serial Number and someone will try to help you.
          all donations are welcome,
          • labo555
            • May 2015
            • 14
            • Italia
            bios asus v230ic
            hi all i need a bios file for my pc asus v230ic with black screen
            the pc turns on but with a black screen
            I am attaching my bios file which I think is corrupt
            thanks achie will help me
            the chip is a winbond 25q128fvsq
            s.n. g7ptcj017296
            • labo555
              • May 2015
              • 14
              • Italia
              Re: bios asus v230ic
              maybe it depends on this chip mxic 25l512e mi-10g
              • labo555
                • May 2015
                • 14
                • Italia
                help me please
                • peste
                  • Dec 2016
                  • 12887
                  • ROMANIA
                  Originally posted by labo555
                  help me please
                  bios extracted from Asus site update..
                  • razor_amd
                    by razor_amd
                    12-15-2020, 07:07 PM
                  • DynaxSC
                    by DynaxSC
                    06-14-2024, 03:49 PM
                  • Ahari
                    by Ahari
                    I...
                    08-13-2025, 06:12 AM
                  • jbonavita
                    by jbonavita
                    Some issues
                    Things I tried
                    04-29-2025, 09:38 PM
                  • kodox
                    Asus ExpertBook B1400CB Bios Dump Needed
                    by kodox
                    need original bios dump, original bios has flashed by other technician before me.
                    attached bios was read from the chip but no display and amperage fluctuating from 0.6A to 0.34 and back to 0.6A.
                    unit info:
                    Model: Asus ExpertBook B1400CBA-0711A1235U
                    S/N: R6NXNZ006657238
                    CN: 7F6F
                    Mainboard Code: B1500CBA R2.1...
                    Yesterday, 12:20 PM
