Bios needed HP 290 G2
Issue : Blink 3-2
Try more bin Still issue same
mobo part no
17514-1 REV:A
348.0A817.0011Attached FilesLeave a comment:
Read the rules, post the serial number etc,etc https://www.badcaps.net/forum/troubl...before-posting -
HP Pro Tower 290 G9 Desktop PC Bundle (8T2H6ES)
i want bios for this model
the pc display not coming,
bios ic xmc ,Leave a comment:
Found the solution.
Just flash Bios from clean HP.
when you boot into bios go to security tab.
Press CTRL+A and open System IDS
You can type in your in here if you cant find them go to https://partsurfer.hp.com/ and type in your serialnumber
Feature byte is case sensitive and you should not type in the spaces.
I did it 8 chareters per line and it worked.
Hi!
I tried to update the bios on this computer and it failed and corrupted the bios.
I tried the hp recovery didnt work.
I downloaded the bios bin for HP flashed it and it boots but i have no serial number etc.
It was in MPM but serial number was readonly could not set it.
DMI tool didn't work too.
The serial number in UEFI tool is in a padding area but it is in different size than the new one.
I have old bios backup and it has serialnumber i found it in hex editor.
Could someone please transer the old data to the new bios.
Serial Number: 8CG9227XK9
Prduct Number: 4NU25EA#AKC
Product family: HP 280
Product Name: HP 290 G2 MT Business PC
CT Number: PGSXT0IK9CCKWK
BID: 19WW1FRD301#SAKC#DAKC
Feature Byte: 2E3Q 3Y6E 6a6y 7J7M 7T7W 7d7j h8.q 8Attached FilesLeave a comment:
Hi!
Thread merged. Post the PC serial number, read the rules https://www.badcaps.net/forum/troubl...before-postingLeave a comment:
Re: Bios needed HP 290 G2
Try This, Its Working for me.
Here's your New BIOS
17514-1 rev.A
Lincs MB
348.OA817.OO11Attached FilesLeave a comment:
Hi Guys, Im facing a similar issue and would appreciate any advice or help. I tried the clean bios listed earlier and the machine booted but now its not turning on again. It seems to turn on intermittently.
I have removed the Cmos battery and when I insert the power cable the fans spin and then stop and then spin again and stop and eventually just stop. If i remove and reconnect the power cable the fans will spin again but even less times until eventually reinserting the power cable shows no sign of life at all.
Does anyone have any ideas on what else could be the issue.? My original bios is attached.
Board is Lincs 17514-1 Rev.A
348.OA816.OO11Attached FilesLeave a comment:
I am facing the same issue for board. What about yours ?Leave a comment:
Re: Hp 290 g2 microtower pc bios dump
Serial Number: 8CG9212MPX.Attached FilesLeave a comment:
Hello
i need bios dump for hp 290 g2 microtower
board number lincs mb
17514-1 rev .a
348.0a817.0011Attached FilesLeave a comment:
Hi. Simpler board came
HP slimline
Newark Rev.A
17520-1
348.0AC92.001
Board starts turns Off..
No display.PL40701 no power.Rest all coils have power .
It has IT8991E 128 DXS is it programmable?
Flashed bios from other site, no changes. I will try this bios from this post too.Leave a comment:
My pc updated bios through Windows Update and I was greeted with BLACK SCREEN WITH CPU FAN MAX SPEED. I don't think there is even a screen signal, because it triggers my monitor for a couple seconds and then the monitor turns off. I tried the other outputs as well.
- I tried clearing bios, resetting bios, removed the CMOS battery, removed m.2 ssd, wifi, and ram. Still black screen with CPU fan blasting.
- I tried using the Lenovo BIOS CD and BIOS USB, but neither worked. At least I couldn't get anything to work.
- I could only locate two chips that look like bios chips. Could someone verify this
by tlindiSublect line continuation: ... Jaguar IDS PC aka Panasonic
Ack
Ack
Channel: BIOS Requests ONLY!
by grimacelordHello there.
I am working on a Lenovo Legion T5-26AMR5 desktop that currently has a corrupt BIOS and I have been unsuccessful thus far in trying to fix it myself.
History:
1. This computer came to me initially with an error message that said "BiInitializeLibrary failed 0xc0000001" or "0135 fan error". It would always be one of the two errors. It should be noted that when it produced the fan error, there was no physical problem with the fans. They were all spinning just fine.
I searched for this error online and discovered...-
by DynaxSCHi, I have an MSI PRO B660M-G DDR4 board with damaged BIOS and i need a bios dump from a real board, along with MAC, UUID and Serial Number info (eg. a BIOS screenshot and pictures from the board stickers).
I need to reconstruct the bios on my board, based on another bios image form a real board - meaning a bios image containing MAC address, UUID and Serial number. A stock BIOS is not suffiecient, as it is impossible to discover where the MAC, UUID and SerialNumber are stored. Tried with a similar board, but there are too much differences, and the stock BIOS is missing a lot of...11-17-2023, 10:56 AM -
by Vesko356First of all thanks to all of our members who have posted previously all methods posted here.
Operating system and OS version.If...-
- Loading...
