HP EliteDesk 800 G2 BIOS corrupted by HP bios update
  • thslr2020
    • Jun 2022
    • 7
    • South Korea
    #101
    Re: HP EliteDesk 800 G2 BIOS corrupted by HP bios update
    Can I add microcodes to support kabylake? I failed(no screen signal) with bios chip flash, so I wonder EC flash can be solution.
    • mehdi_song
      • Jun 2023
      • 6
      • Usa
      #102
      Hi
      Can you tel me how can i find EC and Main BIOS in HP Elitedesk 800 g2 SFF ?
      thanks
      • hoaca388
        Badcaps
        • Jan 2022
        • 11787
        #103
        Originally posted by mehdi_song
        Hi
        thanks
        Look for chips with symbols 64 and 128. For example: 25Q64XXXX, 25Q128XXX..
        • mehdi_song
          • Jun 2023
          • 6
          • Usa
          #104
          Hi
          Please help me
          HP EliteDesk 800 G2 SFF
          S/N: 2UA6462NV8
          No display (DP and VGA)
          No beep
          No error
          • hoaca388
            Badcaps
            • Jan 2022
            • 11787
            #105
            Hi
            Please help me
            S/N: 2UA6462NV8
            No beep
            No error
            • mehdi_song
              • Jun 2023
              • 6
              • Usa
              #106
              first write Bios and second EC(without any desolder EC or Bios)
              whats wrong?
              2 red , 4 white beep and high speed fan without any display after write BIOS
              No power on after write EC
              • hoaca388
                Badcaps
                • Jan 2022
                • 11787
                #107
                whats wrong?
                Try #93
                • mehdi_song
                  • Jun 2023
                  • 6
                  • Usa
                  #108
                  Try #93
                  thanks
                  need to desolder EC or Bios when write or anything ?
                  • mehdi_song
                    • Jun 2023
                    • 6
                    • Usa
                    #109
                    Try #93
                    after write two files , 5 red and 2 white beep
                    • hoaca388
                      Badcaps
                      • Jan 2022
                      • 11787
                      #110
                      You move on to find hardware problems.
                      • mehdi_song
                        • Jun 2023
                        • 6
                        • Usa
                        #111
                        I don't think , because after write files this happend
                        • beast4ever
                          • Feb 2015
                          • 162
                          • egypt
                          #112
                          I need to fix the file, friends
                          • beast4ever
                            • Feb 2015
                            • 162
                            • egypt
                            #113
                            UP
                            • hoaca388
                              Badcaps
                              • Jan 2022
                              • 11787
                              #114
                              UP
                              Next time you have to write down the serial number directly, do not take a photo.
                              HP EliteDesk 800 G2 Base Model Tower PC
                              • lokmanolgun
                                • Aug 2014
                                • 17
                                • istanbul
                                #115
                                Hello. hp 800 g2 twr bios is faulty. It works with another bios, but I need to change the dmi information. can you help?
                                Serial Number : CZC64884RJ
                                Product Number : X3J70EA
                                Description : HP EliteDesk 800/880 G2 TWR​
                                • hoaca388
                                  Badcaps
                                  • Jan 2022
                                  • 11787
                                  #116
                                  Post the file that works for you.
                                  • lokmanolgun
                                    • Aug 2014
                                    • 17
                                    • istanbul
                                    #117
                                    a file previously shared here​
                                    • diegito11
                                      • Jul 2016
                                      • 94
                                      • España
                                      #118
                                      Hello, I have a similar problem to the other users, it turns on and I have no image, I have reprogrammed many BIOS and the result is the same or worse, since now the CPU does not heat up, can you help me?
                                      Attachments​
                                      • hoaca388
                                        Badcaps
                                        • Jan 2022
                                        • 11787
                                        #119
                                        Change DMI
                                        • diegito11
                                          • Jul 2016
                                          • 94
                                          • España
                                          #120
                                          Hola, he puesto otro archivo y ahora la CPU se está calentando de nuevo pero sin video. Creo que la clave es hacer bien el BIOS, pero ¿cuál?
                                          SERIAL CZC6297TVB HP Elitedesk 800G2 SFF
                                          Hi, I've put another file and now the CPU is heating up again but no video. I think the key is to do the BIOS right, but which one?
                                          SERIAL CZC6297TVB HP Elitedesk 800G2 SFF​
                                          in English please..
                                          • Datahoarder
                                            HP Elitedesk 800 G2 DM / Mini -> Can't get BIOS flashed, tried multiple. Update Brick
                                            by Datahoarder
                                            HP EliteDesk 800 G2 MINI/DM (1L PC)
                                            I have 40 of these units. All of which i tried to update bios with HP's utility got bricked. All of them were bios password locked, i used the jumper thing to reset it. Couple updated bios, one of which worked fine for _ONE_ boot. Second is now mixed with rest, i don't know which it is specifically so have not retested it.
                                            All had some MESpilock failed errors on (my) first boot of the unit.
                                            Photo: https://cdn.discordapp.com/attachmen...018_220853.jpg
                                            10-19-2023, 09:33 AM
                                          • FalconPunch
                                            Surface Pro X 1876 Bios corrupted
                                            by FalconPunch
                                            Hello everyone, I happen to have a Microsoft Surface Pro X 1876 in my hands. It was brought to me by a friends which happen to have taken off the bios chip to test another motherboard. Upon putting back the bios chip on the original motherboard, The PC is stucked on Windows logo and won t boot to bios or anything. I suspect that the changes of bios chip somehow corrupted the firmware inside. Is the hypothesis correct?
                                            Also i extracted the bios inside the chip which was on Winbond 25R128JWPQ you can find the file attached if you can fix it (if possible, I would like some insight on...
                                            08-09-2025, 03:56 AM
                                          • intelg
                                            HP Elitedesk 800 G6 lost BIOS admin password
                                            by intelg
                                            Hello everyone, I am looking for help as I am struggling to remove lost BIOS Admin password on an HP EliteDesk G6 800 series desktop. I wanted to reset the vPro remote control IP kvm for homelab use.
                                            Here is the hardware identification specs:
                                            HP EliteDesk 800 G6 Desktop Mini PC
                                            Intel(R) Core(TM) i5-10500 CPU @ 3.10GHZ 16384 MB RAM
                                            BIOS ver S21 Ver. 02.05.01 01/05/2021
                                            Born on date: 07/26/2021
                                            SN MXL11841GN
                                            SKU 3X8V9UCHABA
                                            UUID 8116E79EF6FFE94DB0B98A3188270C5C
                                            SYSTEM BOARD ID 8710
                                            SYSTEM BOARD CT NUKBER PJLHQ0A8JF236L...
                                            11-03-2023, 02:05 AM
                                          • Kashi1712
                                            HP Folio 1040 G1 corrupted bios - new bios flash, unable to update DMI
                                            by Kashi1712
                                            Hello all,
                                            I'm facing a strange issue, I do have my old bios where i can find some information about the laptop SN, build and so on for the DMI encoding.
                                            I did flash a new bios on the laptop and i have tried all the tools found everywhere on this forum and other forums but i'm unable to update all DMI info in the BIOS. I still get an error saying "Warning: Machine is not in committed state".
                                            Could somebody guide me on this or maybe help? I'm really hoping to find a way out of this bios thing...
                                            See attached old bios (corrupted...
                                            05-18-2023, 07:16 AM
                                          • al3m0di
                                            Update bios EFCN58WW to EFCN59WW
                                            by al3m0di
                                            Update bios EFCN58WW to EFCN59WW for solving The Connected AC adapter has a lower wattage than the recommended AC adapter
                                            I have a Lenovo Legion 5 15imh05a device that I bought used online. It came with a 20V 8.5A 170W charger.
                                            The BIOS version is EFCN58WW.
                                            When I turn on the device, it displays the message:
                                            "The Connected AC adapter has a lower wattage than the recommended AC adapter..."
                                            The device rarely charges the battery, and even when it does, it doesn't show that it's charging.
                                            I've tried
                                            07-29-2024, 10:32 AM
