Lenovo C540 AIO bios
  • amatic
    • Oct 2016
    • 12
    • Croatia
    How can I get or reset BIOS password from this machine?
    • 21853
    Re: Lenovo C540 AIO MBO
    By asking in the bios requests sub forum....... ,then posting your bios backup.
    • arminass
      • Mar 2024
      • 5
      • None
      Hi everyone. I'm looking for Lenovo IdeaCentre C540 AIO full bios dump.
      The original bios is password protected and I can't reset it with lenovo autopatcher.
      Can someone help me please?
      Board: VBA00 LA-9301P REV:1.0
      EEPROMs: W25Q32BVSSIG W25Q80BVSSIG
      Here is my dump
      Thanks in advance.​
    • kuch3n
      Maybe this gives you the correct binary: https://pcsupport.lenovo.com/ch/de/p...loads/ds038444 (open with 7zip and extract I0KT33A.bin)
      If you open it with UEFITool, you can see in the information box that this images is for 2 chips, my guess is "ME region" for the smaller EEPROM and BIOS region for the bigger one. It looks very similar to your two binary dumbs (if you concat them).
      You could extract the BIOS region by right clicking and selecting "Extrect as is...", but be aware, i'm just guessing here.. you can brick your system
      • arminass
        • Mar 2024
        • 5
        • None
        Thanks for help, but I'm afraid this too complicated for me.
      • arminass
        • Mar 2024
        • 5
        • None
        That's the problem.
        I don't have a serial number on a back panel (it's erased and in the bios too), just found this:
        Nachine type10110
        Configuration number 57310941
        MO: CS02120315
        CPU I3-3220
        HDD SATA 1Tb
        RAM 8G DDR3
        GPU Intel
        And on MB found that numbers:
        3000025600584
        10E2
        4619KA38L02
        B888E39B6456​
        MB: VBA00 LA-9301P REV:1.0
        EEPROMS: Winbond W25Q32BVSSIG and W25Q80BVSSIG
        • arminass
          • Mar 2024
          • 5
          • None
          Problem solved.
          Found clean dumps, tested. Works fine.
          • Ahari
            by Ahari
            I...
            08-13-2025, 06:12 AM
          • hyperwood
            [REQUEST] 2MB BIOS Dump for Lenovo NM-E471 Rev 2.0 (Winbond 25Q16JWSIQ Chip)
            by hyperwood
            I’m looking for a 2 MB BIOS dump for a Lenovo IdeaPad 5 16ARH7H / Legion 5 with mainboard NM-E471 Rev. 2.0.
            The BIOS chip is a Winbond W25Q16FW (1.8V, 2MB) and it's completely unresponsive / bricked. I tried recovery via USB but no success. Now I want to reflash it externally using a CH341A programmer.
            I already found 32MB dumps (e.g. from Vinafix and Badcaps), but they are too large for the chip – and the last 2MB in those files are just FF FF FF....
            ✅ What I need:
            • A working 2MB BIOS dump
            • Matching NM-E471 Rev. 2.0, e.g. JY575
            06-25-2025, 02:28 PM
          • mkdj
            by mkdj
            Dear all,
            10-19-2025, 04:41 AM
          • Habble7
            by Habble7
            Suspected Cause:
            Troubleshooting Attempts:
            05-22-2025, 07:28 AM
          • mkdj
            Lenovo IdeaPad 3 - Hard Disk not recognized in BIOS
            by mkdj
            Dear all,
            I have recently fixed a Lenovo IdeaPad 3 15 ALC6 that was not booting due to a BIOS issue. After flashing the BIOS, the laptop boots up, but hard disk is not recognized in BIOS. Is says "Hard Disk : Not Installed". I have tried with 2 different drives (one that I know is working on another laptop) but I get the same result. I do not know if disks were recognized before I got the laptop and fix it, but I don't see any reason why not. I can boot on USB though.
            Here the steps I have taken to fix the laptop:
            - downloaded latest BIOS from Lenovo Website...
            10-18-2025, 03:43 AM
