How can I get or reset BIOS password from this machine?
Lenovo C540 AIO bios
Re: Lenovo C540 AIO MBO
By asking in the bios requests sub forum....... ,then posting your bios backup.Last edited by SMDFlea; 08-07-2019, 02:01 AM. -
Hi everyone. I'm looking for Lenovo IdeaCentre C540 AIO full bios dump.
The original bios is password protected and I can't reset it with lenovo autopatcher.
Can someone help me please?
Board: VBA00 LA-9301P REV:1.0
EEPROMs: W25Q32BVSSIG W25Q80BVSSIG
Here is my dump
Thanks in advance.Attached FilesComment
RULES UPDATE for BIOS requests/offers AVOID BANNING, READ BEFORE POSTING
You MUST:- Provide the full machine model number, serial number (or Service tag, SNID) and the board model number (see https://www.badcaps.net/forum/showthread.php?t=88758 ) ,The serial number, make, full model number, motherboard model and revision (except QR codes) must be written/typed at your request as per the rules. Not as a picture, part of the file name and so on.
Maybe this gives you the correct binary: https://pcsupport.lenovo.com/ch/de/p...loads/ds038444 (open with 7zip and extract I0KT33A.bin)
If you open it with UEFITool, you can see in the information box that this images is for 2 chips, my guess is "ME region" for the smaller EEPROM and BIOS region for the bigger one. It looks very similar to your two binary dumbs (if you concat them).
You could extract the BIOS region by right clicking and selecting "Extrect as is...", but be aware, i'm just guessing here.. you can brick your systemComment
Thanks for help, but I'm afraid this too complicated for me.Maybe this gives you the correct binary: https://pcsupport.lenovo.com/ch/de/p...loads/ds038444 (open with 7zip and extract I0KT33A.bin)
That's the problem.
I don't have a serial number on a back panel (it's erased and in the bios too), just found this:
Nachine type10110
Configuration number 57310941
MO: CS02120315
CPU I3-3220
HDD SATA 1Tb
RAM 8G DDR3
GPU Intel
And on MB found that numbers:
3000025600584
10E2
4619KA38L02
B888E39B6456
MB: VBA00 LA-9301P REV:1.0
EEPROMS: Winbond W25Q32BVSSIG and W25Q80BVSSIG
Problem solved.
Found clean dumps, tested. Works fine.
by AhariHi all,
I...-
by hyperwoodHi everyone,
I’m looking for a 2 MB BIOS dump for a Lenovo IdeaPad 5 16ARH7H / Legion 5 with mainboard NM-E471 Rev. 2.0.
The BIOS chip is a Winbond W25Q16FW (1.8V, 2MB) and it's completely unresponsive / bricked. I tried recovery via USB but no success. Now I want to reflash it externally using a CH341A programmer.
I already found 32MB dumps (e.g. from Vinafix and Badcaps), but they are too large for the chip – and the last 2MB in those files are just FF FF FF....
✅ What I need:- A working 2MB BIOS dump
- Matching NM-E471 Rev. 2.0, e.g. JY575
Channel: BIOS Requests ONLY!
by mkdjDear all,
I would appreciate if someone could take time to explain the issue, so that I can learn. But I would...-
by Habble7The Samsung S49CG934SU monitor does not power on - no LED indicator activity and no response to power button. However, when 21V power is connected, it immediately draws 0.8A of current with no display output. The motherboard processor gets warm, and there is continuous reading activity from the W25Q128BV BIOS chip.
Suspected Cause:
Troubleshooting Attempts:
by mkdjDear all,
I have recently fixed a Lenovo IdeaPad 3 15 ALC6 that was not booting due to a BIOS issue. After flashing the BIOS, the laptop boots up, but hard disk is not recognized in BIOS. Is says "Hard Disk : Not Installed". I have tried with 2 different drives (one that I know is working on another laptop) but I get the same result. I do not know if disks were recognized before I got the laptop and fix it, but I don't see any reason why not. I can boot on USB though.
Here the steps I have taken to fix the laptop:
- downloaded latest BIOS from Lenovo Website... - Loading...
