Dell Inspiron 3264 AIO - Bad BIOS?
  • mgrharry
    • Sep 2016
    • 211
    • usa
    Got a Dell Inspiron 3264 AIO unit that just power cycles. No obvious issues with the motherboard, I'm thinking perhaps it got a bad BIOS flash pushed out through Dell autoupdate, especially since I see Dell released a critical BIOS update for this model earlier this month. I've removed the BIOS and dumped it's contents using CH341 programmer, that is attached here.
    The latest Dell BIOS update is available here:
    https://downloads.dell.com/FOLDER056..._AIO_2.7.0.exe
    But when I extract the ROM or HDR file it's ony a 10MB file and from what I gather is encrypted. Got stuck trying to figure out how to decrypt the HDR and merge with the original BIOS dump to create a valid 16MB BIOS image I could use to reprogram with the CH341. Can someone help?
  • peste
    • Dec 2016
    • 12842
    • ROMANIA
    Re: Dell Inspiron 3264 AIO - Bad BIOS?
    try...
    • mgrharry
      • Sep 2016
      • 211
      • usa
      Thank you! Curious how you were able to make it.
      Unfortunately it doesn't seem to have solved the problem. Symptoms are a little different after flashing that and resoldering the BIOS:
      It now automatically powers on when the power is connected, and stays on a few songs longer with fans at full blast, then spins down and the cycle repeats.
        • 20965
        edited: bios removed
        • mgrharry
          • Sep 2016
          • 211
          • usa
          Thank you sir! That did the trick. I owe you a beer.
          Can you explain the process? This won't be the last bricked system I encounter, especially since Dell seems to be pushing out BIOS updates via their pre-installed auto update software.
            • 20965
            Thats great .For everyone else here`s another bios: Insp 3064 3464 3264 AIO_2.7.0 ME_CLEAN.NO_KEY_NO_TAG.BIN ,it has no service tag and no windows key.The key has been replaced with XXXXX-XXXXX-XXXXX-XXXXX-XXXXX at AE3014h .
            • moohjang
              • May 2016
              • 6
              • thailand
              thank you very much
              • Cygnus2
                • Dec 2020
                • 7
                • Brazil
                Hey @SMDFlea - could I have the password via PM? Thanks!
                  • 20965
                  use the bios at post #6, you will have to edit in your win key from your bios backup .
                  • Cygnus2
                    • Dec 2020
                    • 7
                    • Brazil
                    Thanks. The bios backup is gone.
                    After a failed bios update, the machine rebooted into a 3x3 (red and green) beep pattern.
                    A technician soldered a new IC and flashed the one without password, but the AIO now has no activity (no fans, beeps, dead).
                      • 20965
                      Post your service tag number .
                      • Cygnus2
                        • Dec 2020
                        • 7
                        • Brazil
                        • Cygnus2
                          • Dec 2020
                          • 7
                          • Brazil
                          The problem started after freezing (for hours) during this step.
                          • Cygnus2
                            • Dec 2020
                            • 7
                            • Brazil
                            If you have any leads or questions, I can forward them to the technician.
                              • 20965
                              Check the bios chip is Winbond W25Q128FV , Macronix MX25L12805/12835/12845. I don`t know what else to suggest .
                              • Cygnus2
                                • Dec 2020
                                • 7
                                • Brazil
                                The new chip is a Winbond W25Q128BV.
                                The older one is another model.
                                Thanks for the help BTW!
                                • Cmos34
                                  • Sep 2019
                                  • türkiye
                                  Hello; thank you, %100 working Bios.
                                  • Mr.Unique
                                    • Sep 2021
                                    • United Arab Emirates
                                    Thanks a lot for your help
                                    • tomodachi
                                      • Apr 2012
                                      • 602
                                      • Turkey
                                      Thank you very much smdflea, it worked.
                                      • skinner
                                        • Jun 2013
                                        • 54
                                        I was wondering if someone could repair this bios. I have a working bios to get the motherboard working but the hard drive is bitlocked so I want to preserve the original bios so I don't have to deal with figuring out the recovery key.
                                        Model is Dell Inspiron 3464
                                        Service Tag - FYFBZH2
                                        • zenius
                                          by zenius
                                          12-08-2024, 06:13 AM
                                        • Loli Popu
                                          DELL LATITUDE 5590 BIOS CORRUPTED BY CH341
                                          by Loli Popu
                                          Hello guys ,i have a dell latitude 5590 with f411p bios,this laptop has bios password ,i tried to read the bios(winbond 25q128jv) with ch341 but when goes to verify give error ,it said doesnt match .After this i flashed another bios which is cleaned and then the laptop was dead ,i tried to turn on but only white light in the buton power turned on several times and then no display at all .I had a backup and flashed again the original bios ,but this time the laptop will not turn on at all ,no light nothing,the bios original bios that i flashed was having verify error when i verified with ch341 ,i...
                                          12-13-2024, 08:29 AM
                                        • zlr8r
                                          looking for fully extracted by programmer Bios for a Dell Inspiron 17 (7786)
                                          by zlr8r
                                          looking for a fully extracted (by programmer) Bios for a Dell Inspiron 17 (7786) v.1.09 or newer, so I can compare it with my own bios to check for corruption.
                                          cheers
                                          Dell Inspiron 17 (7786) Laptop
                                          Service Tag: 5J0NHT2
                                          Bios: 1.9.0
                                          MOBO: RO 15 17 WHL 2GB MB / 18706-2
                                          Attached;
                                          1. My saved bios using a programmer
                                          2. Dells Bios updater .exe (v1.16)
                                          3. Dells Bios recovery file
                                          4. What I got when i tried to extract the main bios .bin file from Dells Bios v1.16 exe/rcv using some .py script i found online.
                                          5. Image of ME...
                                          12-18-2023, 03:08 PM
                                        • mikeybass
                                          by mikeybass
                                          04-23-2025, 04:30 PM
                                        • GadgetsFix
                                          Dell Inspiron 16 5630 BIOS request
                                          by GadgetsFix
                                          I'm in need of a BIOS file for a Dell Inspiron 16 5630. Unfortunately, I don't have access to the original BIOS file as this is for a replacement BIOS chip installation.
                                          • Model: Dell Inspiron 16 5630
                                          • MainBoard Part Number: 4550SC01C004
                                          • Laptop Serial No: GKH3JX3
                                          • DP/N: 0303KM
                                          • QUAKE N RPL UMA CS MB
                                          • 213251-2
                                          • TMN0H$KB
                                          01-17-2025, 07:38 AM
