Dell Inspiron 3264 AIO - Bad BIOS?
    • 21841
    Originally posted by skinner
    I was wondering if someone could repair this bios. I have a working bios to get the motherboard working but the hard drive is bitlocked so I want to preserve the original bios so I don't have to deal with figuring out the recovery key.
    Model is Dell Inspiron 3464
    Service Tag - FYFBZH2
    Bios from post number 6 + your DMI
    D A40000 - A41FFF
    K AE3000 - AE303F​
    • skinner
      • Jun 2013
      • 60
      D A40000 - A41FFF
      K AE3000 - AE303F​
      I appreciate that. I did try it but it has the same symptoms as the original bios does. But the bios from post 6 worked fine by itself without the changes. Makes me wonder if the DMI of the original bios is the issue. If that is even remotely possible.
      • FatihJones
        • Mar 2018
        • Hell
        Re: Dell Inspiron 3264 AIO - Bad BIOS?
        Thats great .For everyone else here`s another bios: Insp 3064 3464 3264 AIO_2.7.0 ME_CLEAN.NO_KEY_NO_TAG.BIN ,it has no service tag and no windows key.The key has been replaced with XXXXX-XXXXX-XXXXX-XXXXX-XXXXX at AE3014h .
        thank you very much , working
        • zenius
          by zenius
          12-08-2024, 06:13 AM
        • Loli Popu
          DELL LATITUDE 5590 BIOS CORRUPTED BY CH341
          by Loli Popu
          Hello guys ,i have a dell latitude 5590 with f411p bios,this laptop has bios password ,i tried to read the bios(winbond 25q128jv) with ch341 but when goes to verify give error ,it said doesnt match .After this i flashed another bios which is cleaned and then the laptop was dead ,i tried to turn on but only white light in the buton power turned on several times and then no display at all .I had a backup and flashed again the original bios ,but this time the laptop will not turn on at all ,no light nothing,the bios original bios that i flashed was having verify error when i verified with ch341 ,i...
          12-13-2024, 08:29 AM
        • sahamipoor
          need bios dell Inspiron 17 7000 2-in-1 p42e
          by sahamipoor
          hi...
          i need bios of dell Inspiron 17 7000 2-in-1 p42e by chassis Jedi 15/17 cml-mb 18806-1.no display by bios issue.
          i used and flashed ( dell Inspiron 17 7591) by same chassis and worked .but TMP not detect showing. and not enabling in bios(after each reset disable again). Most importantly the booting up display and startup bios (before windows loading) is too many slow!
          i updated to latest version and try other version but not working!
          service tag: HCQ3JW2
          i need your kind....
          10-01-2025, 11:10 AM
        • zlr8r
          looking for fully extracted by programmer Bios for a Dell Inspiron 17 (7786)
          by zlr8r
          looking for a fully extracted (by programmer) Bios for a Dell Inspiron 17 (7786) v.1.09 or newer, so I can compare it with my own bios to check for corruption.
          cheers
          Dell Inspiron 17 (7786) Laptop
          Service Tag: 5J0NHT2
          Bios: 1.9.0
          MOBO: RO 15 17 WHL 2GB MB / 18706-2
          Attached;
          1. My saved bios using a programmer
          2. Dells Bios updater .exe (v1.16)
          3. Dells Bios recovery file
          4. What I got when i tried to extract the main bios .bin file from Dells Bios v1.16 exe/rcv using some .py script i found online.
          5. Image of ME...
          12-18-2023, 03:08 PM
        • mikeybass
          by mikeybass
          04-23-2025, 04:30 PM
