Inspiron One 2330, power on/off continuously - BIOS
  • Blacktek
    • Nov 2014
    • 250
    tought it was the power supply, ordered one, but still doing the same.
    I could use the schematics or bios dump for both chips.
  • IDislikemakingLogins
    • Feb 2017
    • 38
    • moon
    Re: Inspiron One 2330, power on/off continuously
    Just delt with one like that. Was the bios. I used a volt meter to figure out the header under the chips and used a cheep programmer off of ebay. The system would power on and display nothing or would get into a power cycling fest. After updateing the bios it beeped an error, i held the power button down till it turned off and next turn on it worked.
    The bios was found on "a Russian site" according to co-worker but couldnt retrace. I have included pictures of the pin out and the programmer connected.
    • techman1025
      • Jun 2014
      • 497
      Hi
      Before anything start with the easies like the DCjack connector ...so plug in adapter start it up and once it boots and you see the desktop wingle dcjack plug awhile it's in see if it turns off if yes replace dcjack if good ... nexted i would ask you go in the setup and leave it on see if it turns off ..If good see if battery holds a charge if yes remove it awhile you wingle dcjack i don't wont that left in during that dcjack test start dare before bios. I will tell you how to tell if it's the bios '
      Techman1025
      • Blacktek
        • Nov 2014
        • 250
        YOU SIR, ARE A LIFESAVER... PROGRAMMED BIOS AND NOW ITS BEEPING...i LITERALLY REMOVED AND TESTED EVERY POWER TRANSISTOR AND CAPS WITH NO LUCK...EVEN THO ITS ONLY BEEPING..THE PROBLEM HAS BEEN PINPOINTED THANKS TO YOU!..I EVEN ORDER A POWER SUPPLY WHICH I HAD TO RETURN.
        • caspian
          • Oct 2015
          • 1591
          • Laptop
          what is the beeping error code?
          the problem may be a missing voltage.
          • Blacktek
            • Nov 2014
            • 250
            it was 4 beeps, but i tried several memories until i found one that makes it TURN ON and STAYS on, NO BEEPS but no video either, it just stays on.
            • Blacktek
              • Nov 2014
              • 250
              • Blacktek
                • Nov 2014
                • 250
                theres another MXIC MX bios looking chip right next to the winbond, should i program that one as well. if so which file should i use?
                • caspian
                  • Oct 2015
                  • 1591
                  • Laptop
                  are all voltages present on coils when the laptop is turned on?
                  • Blacktek
                    • Nov 2014
                    • 250
                    yep im getting voltages throughout the board, i check the memory slots, and its getting 1.5v on some caps
                      • Feb 2017
                      • 38
                      • moon
                      Both the chips seam to have bios stuff on them. On the one i worked on there where 2 chips 25Q16 2mb, 25Q64 8mb. in my case only needed to update one as the other already had matching code on it. If the size of the MXIC MX chip matches the 2 or 8 in size would back it up and flash it whith the same sized file.
                      May be worth trying to reseat the cpu. Or trying another cpu if easy enough.
                      • Blacktek
                        • Nov 2014
                        • 250
                        So i should flash both chips with the bios dump.
                        • Blacktek
                          • Nov 2014
                          • 250
                          it looks like there is a 3rd bios chip on a separate video board OP-AV rev:0.0, video board has cables from the monitor and from this board to the motherboard.
                          the chip on this small video board is a winbond 25q16.
                          Anyone has the dump for that chip???
                          Please.
                          • tota7
                            • Feb 2017
                            • 15
                            • ISRAEL
                            Please.
                            Hello, i'm sure its too late, but this time i have the same problem and to help another friend in the forum, now i do new and good and test dump for the Av board DELL AIO 2330, chip 25Q16
                            • ktmmotocross
                              Boardkiller
                              • Feb 2014
                              • 3627
                              • slovakia
                              Please.
                              the bigger bios ic is the MAIN bios. bios ic near winbond ic EC bios. bios on graphic card is VBIOS/video bios/
                              u must flash man and ec bios and if no video than vbios
                              • Zvox
                                • Feb 2019
                                • Algeria
                                Hi, I have the same problem bro. Even after bios flash still turn on/off.
                                • TARIQ852
                                  • Sep 2020
                                  • 6
                                  • saudia arabia
                                  Re: Inspiron One 2330, power on/off continuously - BIOS
                                  dell inspiron one 2330 ipimb-dp need bios
                                  • djharold
                                    • Aug 2015
                                    • 246
                                    • COLOMBIA
                                    thanks a lot, wor forme
                                    • iowa
                                      • Dec 2021
                                      • Polska
                                      Hi. Same problem here - POST does not apears.
                                      BUT THE SECOND CHIP IS 25L1606E . Does enyone got a mem dump from it?
                                      • aboumohamed
                                        • Dec 2018
                                        • 258
                                        • algeria
                                        help me
                                        dell inspiron one 2330 aio turn on but no display on the screen. only the selection menu (hdmi vga computer composite) appear and do a scan.
                                        I flashed the 03 bios (main+ec+vga board) downloaded on badcaps but no change
                                        • macabook
                                          by macabook
                                          🧩 Initial Issue
                                          07-24-2025, 02:17 PM
                                        • zlr8r
                                          looking for fully extracted by programmer Bios for a Dell Inspiron 17 (7786)
                                          by zlr8r
                                          looking for a fully extracted (by programmer) Bios for a Dell Inspiron 17 (7786) v.1.09 or newer, so I can compare it with my own bios to check for corruption.
                                          cheers
                                          Dell Inspiron 17 (7786) Laptop
                                          Service Tag: 5J0NHT2
                                          Bios: 1.9.0
                                          MOBO: RO 15 17 WHL 2GB MB / 18706-2
                                          Attached;
                                          1. My saved bios using a programmer
                                          2. Dells Bios updater .exe (v1.16)
                                          3. Dells Bios recovery file
                                          4. What I got when i tried to extract the main bios .bin file from Dells Bios v1.16 exe/rcv using some .py script i found online.
                                          5. Image of ME...
                                          12-18-2023, 03:08 PM
                                        • Vesko356
                                          by Vesko356
                                          08-11-2023, 03:27 AM
                                        • sahamipoor
                                          need bios dell Inspiron 17 7000 2-in-1 p42e
                                          by sahamipoor
                                          hi...
                                          i need bios of dell Inspiron 17 7000 2-in-1 p42e by chassis Jedi 15/17 cml-mb 18806-1.no display by bios issue.
                                          i used and flashed ( dell Inspiron 17 7591) by same chassis and worked .but TMP not detect showing. and not enabling in bios(after each reset disable again). Most importantly the booting up display and startup bios (before windows loading) is too many slow!
                                          i updated to latest version and try other version but not working!
                                          service tag: HCQ3JW2
                                          i need your kind....
                                          10-01-2025, 11:10 AM
                                        • jbonavita
                                          by jbonavita
                                          Some issues
                                          Things I tried
                                          04-29-2025, 09:38 PM
