Asus All-in-one PC ET2220I bios please or repair my backup
  • rxtxgnd01
    • Jan 2012
    • 9
    can anyone give me bios for asus all in one pc et2220i, pc problem hang on asus logo, i try clean motherboard, cpu, and change ram still asus hang on logo then off.
    Product Name: ASUS All-in-one PC
    Model Name: ET2220I
    pn: MT9C21527AU00
    sn: NXCAK215270C030861
    asus et2220i mainboard rev. 1.2
    my backup: http://www.med**********************backup2.bin
    thanks
  • inflex
    • Aug 2012
    • 545
    Re: Asus All-in-one PC ET2220I bios please or repair my backup
    Does it ever provide an error? Try disconnect the HDD, might be faulty.
    YouTube Repair Videos - https://www.youtube.com/user/19PLD73
    FlexBV BoardView software - Linux/OSX/Windows - http://pldaniels.com/flexbv
    • rxtxgnd01
      • Jan 2012
      • 9
      no error just asus logo only pressing power on then turn it off, yes i try that remove all connection except lcd only
      • rioreno
        • Feb 2009
        • 540
        • Indonesia
        Model Name: ET2220I
        pn: MT9C21527AU00
        my backup: http://www.mediafire.com/file/j7h3qb...xu/backup2.bin
        thanks
        try this,
        ver 602 ,extracted from ET2220I-ASUS-0602.ZIP
        https://www.asus.com/AllinOne-PCs/ET...Desk_Download/
        • rxtxgnd01
          • Jan 2012
          • 9
          not working sir, tnx for the help, maybe hardware i will check all the caps and mosfets tomorrow
          • razor_amd
            by razor_amd
            12-15-2020, 07:07 PM
          • grimacelord
            by grimacelord
            07-10-2025, 02:52 PM
          • lrouw84
            Asus vivobook s510ua bios changed to x510un
            by lrouw84
            Hi there,
            I know there is somebody who can tell me what is happening with my laptop. For start, it is an asus vivobook s510ua with an asustek x510ua motherboard with an intel i5 7200u cpu and 16gb ram.. i have a screenshot from speccy before strange things started.. as you can see the laptop type and bios version x510ua.302.I don’t manually update the bios because i don’t like to having a bricked bios, i know what troubles that gives..
            I did a fresh win 11 install, and after the automatic updates, windows rebooted and automatically started asus ez flash.....
            01-28-2023, 01:31 PM
          • ferah831208
            help with bios decompose for Asus s5506ma
            by ferah831208
            I have an Asus s5506ma that was bricked after a Windows update supposedly when it was updating bios. It seems to be a meteorlake Intel CPU core ultra, I cannot find too much info regarding this hardware, anyone have info about if it contains Intel ME engine and if there is any tool for disassemble spi image like we do with all CSME or TXE versions using the appropriate Intel ME tool? The problem is original bios file Asus provides, has bios guard protection, I downloaded the latest update for Ami_pfat_extractor from plomatov (previous versions of AMI bios guard extractor doesn't work),with that...
            08-24-2025, 05:35 PM
          • DynaxSC
            by DynaxSC
            06-14-2024, 03:49 PM
