I need bios for emaxx emx-amd880g-fxn please thanks in advance
emaxx emx-amd880g-fxn bios needed
Tags: None
Re: emaxx emx-amd880g-fxn bios needed
still there is anyone can share a good working bios file for this model it has 2 bios chip ddr2 and ddr3 please share motherboard turn on fan spinning but no displayComment
anyone can share this bios file motherboard has 2 bios and 4 memory slot 2 for ddr2 and 2 for ddr3 please share bios fileComment
Brod, paki tingan dito
Brod, kindly look here
http://******************75Comment
motherboard fan spinning but no display even memory remove no beep sound only fan spinning please help anyone pleaseComment
update already flash the bios but still the same problem cpu fan spinning no display even i remove the memory and turn on no memory there is no beep sound only cpu fan is spinning . Anyone please helpComment
Maybe this one from the emaxx page.
http://www.emaxxtech.com/bios/?wpfb_...mx-amd880g-fxnComment
thanks problem solved i flash the bios and replace the cpu motherboard is working now thanks for the responseComment
by tlindiSublect line continuation: ... Jaguar IDS PC aka Panasonic
Ack
Ack
Channel: BIOS Requests ONLY!
by macabookHello everyone,
🧩 Initial Issue- Board powers on (fans spin, keyboard lights up and can be adjusted, caps lock led lights), but no display or backlight
- External display (HDMI) shows
07-24-2025, 02:17 PM -
by DynaxSCHi, I have an MSI PRO B660M-G DDR4 board with damaged BIOS and i need a bios dump from a real board, along with MAC, UUID and Serial Number info (eg. a BIOS screenshot and pictures from the board stickers).
I need to reconstruct the bios on my board, based on another bios image form a real board - meaning a bios image containing MAC address, UUID and Serial number. A stock BIOS is not suffiecient, as it is impossible to discover where the MAC, UUID and SerialNumber are stored. Tried with a similar board, but there are too much differences, and the stock BIOS is missing a lot of...11-17-2023, 10:56 AM -
by Vesko356First of all thanks to all of our members who have posted previously all methods posted here.
Operating system and OS version.If...-
by iulik17dHello everyone!
The Asrock A380 low profile card (ID 8086 56A5 - 1849 6006) have an power limit of 45W. Intel removed the possibility to increase power using the software utility, anyway the card is in an proxmox machine that doesn't run windows.
The same hardware is in another form by the name Asrock A380 Challenger that have the same VRMs and the power limit is at 60W. I searched online and found on another website an .bin bios file from the Challenger variant, that I flashed using an CH341a. Flashng worked well, I put the card in PC and booted. GPUz shows that new device ID is 8086...-
- Loading...
