I need bios for emaxx emx-amd880g-fxn please thanks in advance
emaxx emx-amd880g-fxn bios needed
Tags: None
Re: emaxx emx-amd880g-fxn bios needed
still there is anyone can share a good working bios file for this model it has 2 bios chip ddr2 and ddr3 please share motherboard turn on fan spinning but no displayComment
anyone can share this bios file motherboard has 2 bios and 4 memory slot 2 for ddr2 and 2 for ddr3 please share bios fileComment
Brod, paki tingan dito
Brod, kindly look here
http://******************75Comment
motherboard fan spinning but no display even memory remove no beep sound only fan spinning please help anyone pleaseComment
update already flash the bios but still the same problem cpu fan spinning no display even i remove the memory and turn on no memory there is no beep sound only cpu fan is spinning . Anyone please helpComment
Maybe this one from the emaxx page.
http://www.emaxxtech.com/bios/?wpfb_...mx-amd880g-fxnComment
thanks problem solved i flash the bios and replace the cpu motherboard is working now thanks for the responseComment
by tlindiSublect line continuation: ... Jaguar IDS PC aka Panasonic
>Read BIOS guides, methods, resources and tools
Ack
>Try the method at BIOS guides, methods, resources and tools before requesting help
Ack
>Explain you were not able to succeed with the methods at BIOS guides, methods, resources and tools
python ./main.py "/mnt/c/temp/205605f9e1b60403a41787efeffe9cad-flas_maybe5.BIN" --output-dir "/mnt/c/temp/205605f9e1b60403a41787efeffe9cad-flas_maybe5.txt"
Channel: BIOS Requests ONLY!
by macabookHello everyone,
07-24-2025, 02:17 PM -
by DynaxSCHi, I have an MSI PRO B660M-G DDR4 board with damaged BIOS and i need a bios dump from a real board, along with MAC, UUID and Serial Number info (eg. a BIOS screenshot and pictures from the board stickers).
I need to reconstruct the bios on my board, based on another bios image form a real board - meaning a bios image containing MAC address, UUID and Serial number. A stock BIOS is not suffiecient, as it is impossible to discover where the MAC, UUID and SerialNumber are stored. Tried with a similar board, but there are too much differences, and the stock BIOS is missing a lot of...11-17-2023, 10:56 AM -
by techlabHi Guys,
Looking for some help with an HP Elite Dragonfly.
The customer explained it was updating the BIOS, the flashing completed, but afterwards the laptop wouldn’t power back on.- The laptop has no power but does take the correct voltage.
- It shows 5 flashes white/amber, which indicates a BIOS issue.
- I backed up the original BIOS to extract the feature byte etc.
- I then flashed the BIOS with a clean version from HP’s website, but the laptop still gives 5 white/amber flashes.
Just wanted to pick your brains on this — has anyone come across this before or...-
- Loading...
