Need BIOS for ASUS P4BGL -MX
  • balattc
    • Feb 2015
    • 153
    • india
    ASUS P4BGL -MX bios need
    only need bin
    i have bios bios programmer
  • c_hegge
    • Sep 2009
    • 5219
    Re: Need BIOS for ASUS P4BGL -MX
    1. Please post in the right forum. I have moved this thread from the ECS/Epox/Gigabyte to the correct forum
    2. Please be more specific in the title than just "asus". Also fixed
    3. Download it from the ASUS website - http://support.asus.com/Download.asp...GL-MX&p=1&s=15 . It takes a whole 30 seconds to find it in Google!
    • razor_amd
      by razor_amd
      12-15-2020, 07:07 PM
    • grimacelord
      by grimacelord
      07-10-2025, 02:52 PM
    • STKR123
      The right BIOS Programmer - The right software (HP Elitebook 820 G1, 840 G2) no soldering, EC, DMI, ME
      by STKR123
      Greetings badcaps community,
      I havent done this for a long time and want to start it all again, after some evil and annyoing illness.
      So I apologize in advance, if some phrases might sound a bit like gibberish or illogical to you.
      Im trying my best to fully describe what I plan to achieve and hope I was choosing the right sub-forum for my new adventure.
      I have a Elitebook 820 G1 and a Elitebook 840 G2 here.
      These ask for a password when entering the BIOS, but boot just fine from the internal SSD.
      I learned that desoldering...
      10-29-2024, 06:03 AM
    • throwaway327
      by throwaway327
      Model No: RC72LA
      Serial No: SBNVKD001014459
      06-18-2025, 05:52 PM
    • hotcrossedbuns999
      M715q Desktop (ThinkCentre) - Type 10M3 - Request bios chip location and useable bios for use with CH341A Programmer.
      by hotcrossedbuns999
      My pc updated bios through Windows Update and I was greeted with BLACK SCREEN WITH CPU FAN MAX SPEED. I don't think there is even a screen signal, because it triggers my monitor for a couple seconds and then the monitor turns off. I tried the other outputs as well.
      1. I tried clearing bios, resetting bios, removed the CMOS battery, removed m.2 ssd, wifi, and ram. Still black screen with CPU fan blasting.
      2. I tried using the Lenovo BIOS CD and BIOS USB, but neither worked. At least I couldn't get anything to work.
      3. I could only locate two chips that look like bios chips. Could someone verify this
      01-03-2025, 12:32 PM
