msi ms-7616 mainboard bad bios flash
  • anno
    • Sep 2007
    • 140
    • netherlands
    hi i have problem with msi ms-7616 mainboard (medion pc). i updated the bios and now it hangs at bios screen. it doesn't continue to boot. i see bios screen with
    initializing usb controllers...done
    2040mb OK
    help. i have older bios version, it is a .10F file. the original bios is 4 mb size, the correct .10F file is 2 mb. i don`t understand this
    i tried to flash the 2 mb .10f file but the pc was dead then.
  • anotherdude
    • Feb 2013
    • 488
    • uk
    Re: bad bios flash
    reset bios with cmos jumper
    • anno
      • Sep 2007
      • 140
      • netherlands
      Re: bad bios flash
      i did but didn't help
      • kc8adu
        • Nov 2003
        • 8832
        • U.S.A!
        Re: bad bios flash
        sounds like you got the wrong image.
        hopefully it has a bad flash recovery trick.
        if not time to pull the e/eeprom and use a programmer.
        • SteveNielsen
          Retired Tech
          • Jun 2012
          • 2327
          Re: bad bios flash
          Kinda gives me a longing for the good ol' i8086/80286 days when BIOS chips were socketed.
          • xxxvirus1987xxx
            unlegendary
            • Sep 2014
            • 24
            • philippines
            Re: bad bios flash
            u need a correct bios set up for that...reflash again using a corrent bios firmware for that.
            • anno
              • Sep 2007
              • 140
              • netherlands
              Re: bad bios flash
              hi
              i desoldered the chip and flashed with a programmer, but the pc has a black screen then.
              http://www.medion.com/nl/service/_li...s.php?did=8685
              maybe it is not the correct bios file?
              • S2udio
                • Feb 2012
                • 16
                Re: bad bios flash
                Try going back....to before you unsoldered the chip
                Then flash with the appropriate flash bios program and correct bin file.
                Ahh ......that would break the laws of time !
                Most soldered eproms have a couple of access pcb tracks to facilitate on board serial programming.
                Maybe Bin... is the correct term
                Most of the time things ain't what they seem to be
                • reaper57
                  • Sep 2014
                  • 216
                  • Norway
                  Re: bad bios flash
                  I'm usually not the person to tell you to buy a new one instead of repairing it, but these chis often cost a few $ pre-programmed.
                  Keyboard not detected, press F1 to continue...
                  • techman1025
                    • Jun 2014
                    • 497
                    Re: bad bios flash
                    Hi
                    The problem is that the update is not a full update it has no Me region. look all ffffff in the first half ..you need to merge the original file first 1,048576 to the update and save it then total size should be 2,097152 so then it will be the same has the original ..if you don't know how to do it i will do it for you ...now if fans ,or it boot and cycle's off then i will rebuild the me region for you.
                    Techman1025
                    • bimeric
                      • Apr 2018
                      • Netherlands
                      Re: bad bios flash
                      Techman1025 youre a hero!
                      Combined the original me and the update (makes 4mb in this case)
                      Here are the H55 and P55 versions with ME region added!
                      https://drive.google.com/open?id=13a...rWgkuMtoDNFe23
                      Works for me on msi ms-7616 mainboard (P55 in my case)
                      • techman1025
                        • Jun 2014
                        • 497
                        Re: bad bios flash
                        Cheers good job
                        techman1025
                        • johnpaul11
                          • 9
                          • Philippines
                          Re: bad bios flash
                          Sir techman1025
                          • guzonjinsin
                            • May 2018
                            • bosnia and herzegovina
                            Re: bad bios flash
                            I think this is fix for me but i dont know how to properly install this bin file
                            Quick guide pls ?
                            • techman1025
                              • Jun 2014
                              • 497
                              Re: bad bios flash
                              Quick guide pls ?
                              You need to back up original bios file first using a external programmer like a TL866-A after that you would upload your original file here i will rebuild it for your you machine then reupload it for your laptop then you would reflash chip with my fixed bios done.
                              Techman1025
                              • albert-arabasz
                                • Apr 2020
                                • Polska
                                Re: bad bios flash
                                Hi!
                                You could throw in these converted bios again because the link is no longer active
                                • bitterpea
                                  • Apr 2022
                                  Re: bad bios flash
                                  I've messed up a BIOS flash before, to be fair if you actually email the manufacturer they'll be able to supply you with a replacement chip for you to fit yourself. It's the easiest thing to do and they'll preflash it for you. I think Asus charged me about £15 a few years ago and it arrived in a couple of days, then I just fitted it myself.
                                  • to5it0
                                    by to5it0
                                    10-24-2025, 01:35 AM
                                  • abhorsen
                                    Help Disabling Flash Protection Range Registers on Lenovo P360 Tiny BIOS
                                    by abhorsen
                                    Hey guys,
                                    Hope you all are doing well. I come here from Win-Raid because I am having issues disabling Flash Protection Range Registers so I can flash my BIOS from within Windows using Intel's IFW tool/using flashrom within Linux, however I cannot due to the above mentioned error.
                                    Here is my thread on Win-Raid detailing the whole process I went through: https://winraid.level1techs.com/t/re...h-gen/95478/27
                                    Essentially I managed to boot into Windows while shorting PINs 1+5 of my audio chip to disable the HAP bit...
                                    07-06-2023, 10:22 AM
                                  • survivalbloke
                                    If I flash this bios file, will it just work, or does it need the ME cleaning?
                                    by survivalbloke
                                    I'm not a super pro like some here, when it comes to firmware. I have a machine with the following specs:
                                    ENVY X360
                                    15-ew0013dx
                                    SN: CND2261KS3
                                    Prod: 698V0UA
                                    Board: LA-M021P Rev 1A
                                    Chip# Winbond 25R128JVSN​
                                    Basically, when I power it up, I get no video, and the fans run hard - nothing else. Seems like a BIOS issue to me, so I posted a request in the BIOS request section. I haven't heard anything back(and that's fine) So I tried downloading the BIOS from HP, then I extracted it and flashed it onto the chip. Unfortunately, all I get is the power...
                                    10-09-2024, 08:40 AM
                                  • Citymin
                                    by Citymin
                                    S/N : 5RNK9FFT70...
                                    08-05-2025, 05:12 AM
                                  • testaccgta
                                    Unable to verify IC or write/erase/flash BIOS file to XMC QH128AHIG SPI chip using NeoProgrammer/AsProgrammer
                                    by testaccgta
                                    Hi, everyone!
                                    I've recently acquired two brand new SPI chips to replace the one currently in my Acer A514-54G laptop MB (FH5AT LA-K092P). The reason why I'm replacing the current SPI chip is because I had some difficulties with a third-party IT assistant who pretty much lacked the soldering skills and ended up destroying the current SPI chip soldered to my MB from factory.
                                    I've decided to do this on my own because I spent the past month or so learning some soldering skills and BIOS modding through Badcaps and WinRaid forums, hence the attempt. I've also chosen to buy...
                                    09-01-2024, 08:24 PM
