intel/asus nuc8i3beb bios+ec ite
  • guruji
    • Oct 2012
    • 124
    • India
    hello all,
    Please can someone upload ec bios for ITE8987vg as the machine has no power accept 3.3v 5v and 1.0v.i put a new ec and after that i see power led blue come on but still the control signal dont come.is there a way to extract the ec bios from the main bios.
    thanks
    ohh how do i flash the ite8987 on this board as there is no kbd connection.I read in one of the forums flashng it with smbus mode.
  • Inverteddragonx
    • Nov 2025
    • 5
    • Poland
    Hi guruji,
    Did you manage to solve this problem? I have exactly same issue. I've been gifted broken nuc8i3beh/nuc8i3beb and previous owner tried to repair it himself and deleted both BIOS and EC. I did build BIOS file but without EC device is not reacting to power button.
    • guruji
      • Oct 2012
      • 124
      • India
      Hi no I couldn’t get the ec rom. But I know for sure it is the ec rom also to flash it there is no way on the board need to flash it with the bga adapter or in another laptop.Also the bios file does not contain the ec rom. I finally had to give back to the customer.
      • Inverteddragonx
        • Nov 2025
        • 5
        • Poland
        Hey, I also have this nuc model, and I also thought the EC was dead because the device was lighting up the green LED next to the SATA port, but after connecting the power supply, it wouldn't start or respond to the power button. I managed to get a BIOS dump from such a device, and after flashing it to the nuc chip, it started with a black screen and no POST, but it's still causing problems. You can check out my other post on this topic.
        https://www.badcaps.net/forum/troubl...8i3beh-bios-ec
        • razor_amd
          by razor_amd
          12-15-2020, 07:07 PM
        • pirati
          by pirati
          10-27-2025, 04:20 PM
        • grimacelord
          by grimacelord
          07-10-2025, 02:52 PM
        • jbonavita
          by jbonavita
          Some issues
          Things I tried
          04-29-2025, 09:38 PM
        • throwaway327
          by throwaway327
          Model No: RC72LA
          Serial No: SBNVKD001014459
          06-18-2025, 05:52 PM
