Asus Prime X570-P Bios
  • Prono113
    • Jan 2020
    • 41
    • Vietnam
    No serial number and ST
    IT's working, capslock and numlock lights are on. But no display
    Pls, clearme. TKS
  • SoporteNetFe
    • Aug 2021
    • 112
    • Argentina
    AMD dont use ME firmware... I attach same BIOS version, but from Asus.
    • Prono113
      • Jan 2020
      • 41
      • Vietnam
      The situation is still the same, probably not due to the bios. Thank you very much.
      • m1ch43lzm
        • Mar 2019
        • 389
        • Peru
        Which CPU are you using to test?
        BIOS 1005 is very old, only for Ryzen 3000 series CPU
        Also, try with a known working graphics card in both PCIe slots
        Latest BIOS is 5031 according to ASUS website
        https://www.asus.com/latin/motherboa...e=PRIME-X570-P
        • Prono113
          • Jan 2020
          • 41
          • Vietnam
          I use amd 3900X. So is there any article that can guide me to separate bios from asus homepage into bin file. Please guide me
          • SoporteNetFe
            • Aug 2021
            • 112
            • Argentina
            CPU Ryzen 9 3900X Validated since BIOS 0602 from Asus page...
            • m1ch43lzm
              • Mar 2019
              • 389
              • Peru
              Download UEFITool NE (click on "Show all 17 assets") UEFITool_NE_A72_win64.zip
              https://github.com/LongSoft/UEFITool/releases
              Open the BIOS .cap from ASUS website, double click on "AMI Aptio Capsule", right click on "UEFI Image" and select "Extract as is", and save it to a new file, should be 33,554,432 bytes
              Attached here
              I'm stating the obvious, but the monitor should be connected to the graphics card (not to the HDMI port on the motherboard), as the 3900X doesn't have integrated graphics
              Have you tested with another graphics card?
              Prono113 didn't specify CPU model on first post, and AM4 boards support different CPUs, with newer CPUs requiring a BIOS update (depending on motherboard and installed BIOS version), it's best to know which CPU you have first
              Latest BIOS officially supports Ryzen 2000-3000-4000-5000 series CPUs
              • Prono113
                • Jan 2020
                • 41
                • Vietnam
                Attached here
                Thank you very much. My PC is working but the graphics card only works in the 2nd pcie slot. I think the socket or cpu is the problem but maybe I should just use it for now.
                • razor_amd
                  by razor_amd
                  12-15-2020, 07:07 PM
                • grimacelord
                  by grimacelord
                  07-10-2025, 02:52 PM
                • throwaway327
                  by throwaway327
                  Model No: RC72LA
                  Serial No: SBNVKD001014459
                  06-18-2025, 05:52 PM
                • DynaxSC
                  by DynaxSC
                  06-14-2024, 03:49 PM
                • jbonavita
                  by jbonavita
                  Some issues
                  Things I tried
                  04-29-2025, 09:38 PM
