ASUS TUF B550-Plus Bios request
  • Nussbacker
    • Jan 2025
    • 8
    Hey,
    anyone got a bios for the ASUS TUF B550-Plus board? Need the non wifi edition.
  • hoaca388
    Badcaps
    • Jan 2022
    • 12329
    Originally posted by Nussbacker
    Hey,
    Post bios backup even if it is corrupted.
    • xebbmw
      • Apr 2014
      • 8
      How are you gone write to the flash chip? Using an adapter (like CH341A programmer) and the corresponding software?
      If yes, why don't you download it directly from Asus website and unzip the file. Then open CAP file using UEFI Tool and do select: Action - Capsule - Extract Body. The resulting file you may write it back to the flash chip using the programmer.
      • Nussbacker
        • Jan 2025
        • 8
        You are right, thanks for the tip. Think I started out with the whole BIOS flashing with a dell laptop and then an x570 which was not as is extractable for some reason, It's a learning experience. This time arround it just worked.
        Extracted BIOS attached
        • jbonavita
          by jbonavita
          Some issues
          Things I tried
          04-29-2025, 09:38 PM
        • razor_amd
          by razor_amd
          12-15-2020, 07:07 PM
        • pirati
          by pirati
          10-27-2025, 04:20 PM
        • grimacelord
          by grimacelord
          07-10-2025, 02:52 PM
        • DavidChunco
          Dell G15 5515 Ryzen Edition Apparently Bricked BIOS Request
          by DavidChunco
          Hi, I hope someone can help me with this, my Dell G15 Ryzen Edition does not post anymore (black screen, no Windows boot, no BIOS screen) after Windows Update pushed what appears to be a buggy bios image, I've tried the following with no success:
          - Receive help from Dell Support (it is out of warranty).
          - Disconnect machine from AC power and battery overnight.
          - BIOS recovery process
          - Connected external display via HDMI
          - Disassembled machine and found bios chip, its a Gigadevice 25LR128DSIG (GD25LR128DSIG), at first I tried to get it detected by CH341A (with...
          03-15-2025, 11:00 AM
